codesx codesx is offline
Default What is THE best N54 manual, from an Electrical perspective? - 07-25-2018, 09:31 AM
Hi all,
I know there are Bentley and other manuals.
I'm trying to determine which is the best from an electrical troubleshooting perspective.
2008 335i Convertible, E93, N54, A/T
TUNE: JB4 Map 1 | PUMP BEF | 94 Octane | @15 PSI
BMS: JB4 | 5" FMIC | OCC | DCI
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
NGK 5992 Plugs @ .020
RB PCV Valve
Pending Install:
BMS WMI
Maintenance:
2018, Q2 - Plugs | Ign Coils | Walnut Blasting
2019, Q1 - Valve Cover Gasket | OFHG & O-rings | Alternator w/ Clutch Pulley | Manually scrubbed Intake Ports w/ CRC Valve & Turbo Cleaner
rkreimer10 rkreimer10 is offline
Car: 08 535i
Default 07-26-2018, 08:18 AM
https://www.newtis.info
Good info
Car: 08 535i
Default 07-26-2018, 08:19 AM
Ista+ is probably the best as it is very in depth, if you know how to use it
Default 07-26-2018, 11:09 AM
Thanks rkreimer10.
I checked the link about, but didn't locate any vanos specific detail.
Ista+, is that the interactive diagnostic software? Or is there also a 'manual' of sorts?
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Pending Install:
BMS WMI
Maintenance:
dmckmc dmckmc is offline
Car: E60 535i
Default 07-26-2018, 11:31 AM
Bentley has thorough wiring diagrams and connection location pictures woth OBD II/BMW code listings. It does not have detailed, pin point diagnosis steps with expected voltage readings you are probably looking for.
N54
FBO
JB4
BEF-E85
E40
PCV-EXT
XHP
Default 07-29-2018, 06:52 PM
Thanks for that dmckmc.
In the end, if nothing else pops up, I'll likely buy Bentley.
I like good mechanical info, but also solid electrical info. Too bad most stuff focuses on mech.
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Pending Install:
BMS WMI
Maintenance:
