Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
administartor
Car: F80 M3
Default BMW M235i with BMS Wheel Spacers - 08-30-2014, 12:31 AM
On this 2014 F22 M235i I added a pair of BMS 10mm wheel spacers to the front and a pair of BMS 15mm wheel spacers to the rear. Looks perfect and complements the wheels nicely. Any width of the BMS wheel spacers will fit the F22/F23 2 Series vehicles. On the M235i with factory wheels and tire sizes I recommend 10mm front and 15mm rear.
BMS Wheel spacers are available in 10mm, 12mm, 15mm, 18mm and 20mm widths for only $99.00 a pair including 10 extended lug bolts needed for a complete install.
http://www.burgertuning.com/BMW_wheel_spacers.html
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 08-30-2014, 07:51 AM
335is DCT
Roshi Roshi is offline
Car: M235i
Default 09-10-2014, 01:06 AM
Any issue with fitting the dust cap?
administartor
Car: F80 M3
Default 09-12-2014, 07:57 PM
If in the rare case you have dust caps over the factory hubs you must remove them. Then put the spacer on. If the dust cap is not removed and the spacer is fitted over the dust cap it will cause the spacer to not seat properly and have gaps between the spacer and rotor hat.
A customer silicon glued them to the hub on the spacer. Didn't seem like a bad idea.
