Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
administartor
Car: F80 M3
Default 2014 F10 M5 with BMS Wheel Spacers! WOW! - 04-25-2014, 12:58 AM
Just fitted our 2014 F10 M5 with BMS wheel spacers and what a difference in looks and handling! The perfect size BMS spacer set up for this car is 15mm rear and 10mm front. Besides this car being scary fast it now looks scary good. See for yourself below.
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 04-25-2014, 05:47 AM
Oh wow indeed, need me some spacers for my family boat
What you think jason, best set up for this ? Same maybe 10/15?
administartor
Car: F80 M3
Default 04-25-2014, 10:13 PM
10mm seems to be just perfect for these F Chassis vehicles. I agree with the 10mm front and 15mm rear combo on the 7. That will look great.
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 04-27-2014, 03:06 AM
Looks great! Such a simple mod but really changes the appearance of your car!
335is DCT
administartor
Car: F80 M3
Default 04-28-2014, 12:50 PM
They also widen the wheelbase making the car handle better. BMS Spacers are an amazing bolt on mod for sure.
watson335i's Avatar
watson335i watson335i is offline
Car: Future 2013 335i M Sport
Default 04-29-2014, 05:38 AM
Jason I have a F30 335i with A G rims (310)...ET-35fr / ET-43rr. Stock set up, 235/35/19FR - 275/30/19R. What size spacers do you recommend?? Looks great!
2014 335i M Sport / Est Blue / Blk Dakota / Tech / Prem / CW / DHP / HK / AV HYP Slvr 310's-19 / Mich PSS 235/35FR-275/30R / Blk Kid Grill / Tint-35% / Borla ATAK / JB4 Map 1/ H&R / BMS Intake / Wagner Intercooler
watson335i's Avatar
Default 04-29-2014, 06:40 AM
Here is my car...before I got Borla...Name:  2014 335i M Sport ESTORIL BLUE 007.jpg
Size:  249.1 KBName:  2014 335i M Sport ESTORIL BLUE 005.jpg
administartor
Car: F80 M3
Default 04-29-2014, 06:15 PM
Doesn't look like you need spacers on your car. 15mm+ is the smallest thickness spacer the 2012-2014 F30 and F31 vehicles may use in the rear. Front can fit 10mm and up. This only applies 2012-2014 F30 and F31 vehicles.
Why is this? Because the rear hub of the F30, F31 is too tall to accommodate a 10mm or 12mm spacer. The 10mm and 12mm spacer wont sit flush on the rotator hat. The F30 and F31 are the only F chassis vehicles that have this issue. You can grind down the hub a few millimeters if you want thinner than 15mm spacers on the rear of the F30, F31. All other F chassis vehicles can accept 10mm and 12mm spacers in the rear. Including the 2 Series.
The F chassis vehicles have a very thin inner rear fender from the factory. Feel under there. It is nice and thin for wider tires or wide spacers.
