arkie6 arkie6 is offline
Car: 2008 335i
Default First logs, new JB4 and new LPFP sensor - 01-20-2019, 10:29 PM
I've had my JB4 installed a couple of months with no real issues other than a code for the low pressure fuel sensor after I first installed the JB4. I initially replaced it with a cheap version on ebay and it locked in an 84 psi reading so I decided get a real BMW sensor along with the new fuel supply pipe for the new style sensor. Everything appears to be working fine now with the low fuel pressure indicating around 72 psi at idle and dropping slightly under higher engine demand.
The following log was taken today with outside temperature ~32F, 93 octane, JB4 Map 1, and no other mods. The car seems to pull strong and run good. Does anyone see any issues that I'm overlooking or other parameters that I need to log?
Default 01-21-2019, 07:41 AM
Hey,
Overall this looks pretty good!
Boost looks pretty spot on, timing looks fine as well
Hpfp / LPFP values look stable as well.
One thing Id suggest is enable your 6cyl timing in your user adjustment so we can see multiple cylinders.
Also, you may want to consider trying the pump BEF
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
