D1RTY_B1RD D1RTY_B1RD is offline
Car: Bmw 335i
Default Data Log Review - 01-10-2019, 06:31 PM
Any guidance is appreciated. I'm new to JB4 and tuning in general.
MODS: MPPK, MPE, VRSF ******* ********, ER charge pipe, Dinan "big" turbo, JB4 w/ FF wires, EWG wires, JB4 mobile. Running E31 and cali 91 mixture.
Overall i would like to create a map 6 with your help.
I have provided a quick map 5 data log. I've read over the jb4 bible and multiple threads. This all seems like a science to me. Like before, any guidance, tips, or anything in general will be much appreciated. Thank you.
Default 01-10-2019, 10:25 PM
Biggest issue I see at this point is timing. Seems to crap out up top. Add another gallon of e85, letís see if we can keep timing & we can work on dialing in a custom map in the near future.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 335i
Default 01-11-2019, 11:16 PM
Recalculated my ethanol percentage. Turned out i wasn't running E30. I added another gallon of E85 today, totaling 4.2 GAL. I just did 3 logs. Map 1, 2, and 5.
map 2 and 5 feel very similar.
Thank you for reviewing my logs.
Default 01-12-2019, 03:30 PM
These look a good bit cleaner- which map do you plan on using daily?
Which feels best?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 335i
Default 01-12-2019, 06:14 PM
Which feels best?
Between map 2 and 5 i feel almost no difference. Ill probably run map 2/5 daily and run map 6 for some spirited driving once you feel we can create it.
Car: Bmw 335i
Default 01-13-2019, 10:21 PM
Does any one else have any insight or any input about the graphs above? Thank you!
I just did another map 5 log after a few days of some daily/spirited driving. Did this one with DSC off instead of sport+. Felt a little stronger.
Default 01-14-2019, 11:14 PM
Boost looks good, right at or around target.
Timing falls out a bit up top, not super uncommon as map 5 learns
Was this the first wot pull?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 335i
Default 01-14-2019, 11:20 PM
Dave, no it wasn't. I've done a few the past week on the way home from work using map 5. Any suggestions?
Car: Bmw 335i
Default 01-17-2019, 03:00 PM
Bump
Default 01-22-2019, 12:39 PM
Do 2-3 pulls with 5 first & then get me a log after that.
e92 AT 335xi 2.0
Doc Race Kit 6062
