Havoc0923 Havoc0923 is offline
Car: 135i n55 6mt
Default Flex fuel wires added now car is running weird help! - 01-14-2019, 03:34 PM
I added the flex fuel wires a few days ago now the car feels like it's misfiring when I go wot. It hard to log because of this plz help
E82 n55
******* d0wnpipe
2 step intercooler
Bms intake
Bms charge pipe
Jb4+mhd bef pump map 2
Default 01-14-2019, 03:38 PM
What codes?
Car: 135i n55 6mt
Default 01-14-2019, 04:11 PM
2EFE
2F01
2EE0
2EEA
2F02
2EED
changed my coils and cleared codes. Codes have not came back but its still feels like its misfiring. Also my lpf pump in the log is kinda low at wot it only went to 25 shoukd it be higher?
drwillb drwillb is offline
Car: 2012 n55 135i
Default 01-14-2019, 04:25 PM
Our cars (e82 n55) do not have LPFP sensor so the numbers you see in the log for that field are irrelevant. Now that you have the FF wires you need to look at HPFP and trims values. If they are good then your LPFP is good.
Car: 135i n55 6mt
Default 01-14-2019, 05:17 PM
Thanks I didn't know. What should the trims and hpfp be at?
Default 01-14-2019, 05:46 PM
Misfire codes. Let's see a JB4 log at lower boost levels like map0 or map1.
Car: 2012 n55 135i
Default 01-14-2019, 07:38 PM
First of all, get a log as per Terry.
HPFP value will vary depending on map/fuel demands. Iím seeing 15 and 16 on map 6 with a 16psi target (I canít go higher due to snow tires on the car). Iím also getting some trims up to 32 momentarily then back down to 25.
