bmwjon bmwjon is offline
Car: 2017 BMW 340i
Default 17 340i Stock whp with mods?? Help! - 07-20-2017, 05:28 AM
Hey everyone so I have a 17 340i 6speed rwd with BMS Intake, jb4 with ewg harness, c***** d*, and armytrix exhaust. I dyno'd the car not too long ago and only made 338 whp. That's stock power. I was running map 2 at the time. I read a thread with another user making 39x whp. Am I doing something wrong? Or is the jb4 itself not working properly. Any input would be greatly appreciated
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 07-20-2017, 05:54 AM
Post the graphs and post the logs... without that not much advice can be offered..
Someone else with the same setup just did a dyno and achieved over 420 hp..
It's posted somewhere in this forum....
I want to say Dyno are not all that accurate and can vary from one to another... he best test is to always do a base line then apply your upgrades... if you have a map 0 run post that... the delta is more important than the actual number ..
If not , go back and run a map 0... and lets see
And if you didn't get jb4 logs - get those too..
jalkster jalkster is offline
Car: 340i M-Sport
Default 07-20-2017, 06:09 AM
gotta see the logs. unless the dyno tech wasnt very with it, you may even have a disconnected wire. I would like to hear that exhaust set up though.
16' 340i Ohlins R&T | ER ** | AP Intake | 437M | MPSS
Car: 2017 BMW 340i
Default 07-20-2017, 06:18 AM
I'd have to take some more logs. Will post later on
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 07-20-2017, 01:33 PM
Logs are definitely needed but without them I would say not high enough octane.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
2014 E84 X1 35i 13.19 @ 102MPH / 0-60 4.73 / 293 AWHP 305 AWTQ When stock
ER Chargepipe | BMS Intake | JB4 ISO |
Default 07-20-2017, 01:35 PM
Would need to see the dyno log and print out for any advice. If its a MD dyno you're making more than you should be. But if its a dynojet less than you should be. Log will shed more light on why either way.
Car: 2017 BMW 340i
Default 07-20-2017, 06:17 PM
Okay so. I switched to map 1 and the car feels so much better.
Lemme know if you guys wanna see anything else
Default 07-20-2017, 07:27 PM
Didn't record any runs on the dyno? That is what we'd want to look at if trying to isolate a power issue.
Car: 2017 BMW 340i
Default 07-20-2017, 07:30 PM
Looking to get back on dyno this weekend. Will post multiple logs
Default 07-20-2017, 07:33 PM
OK, don't see any obvious issue in the short logs here. For dyno testing be sure to find a dynojet and do a run or two on map4 (stock) for comparison.
Car: 2011 e92 335i
Default 07-21-2017, 11:11 AM
If you were running Map 2 on the dyno I would say poor timing was what kept you from making more power. When doing logs in the future you need to log 3rd or 4th gear for most of the gear to get any usable data.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Car: 2017 BMW 340i
Default 07-29-2017, 07:09 PM
So I finally got another dyno run at bimmerfest east. I've also been emailing Terry to get things straightened out. So I'm posting the logs I took for you guys to see
Also have the dyno sheet. But can't upload file says it's too big Best hp I made was 417.9 on 100 octane and map 5
2017-07-29 11_53_12.csv
2017-07-29 11_55_56.csv
2017-07-29 11_50_18.csv
2017-07-29 11_59_19.csv
Car: 340i M-Sport
Default 07-31-2017, 06:53 AM
Attachment 65849
Attachment 65850
Attachment 65851
Attachment 65852
Id like to see the dyno sheet if you could downsize it or something... did you get in a baseline run?
Car: 2017 BMW 340i
Default 07-31-2017, 09:22 AM
Looks like I was able to get it downsized. The sheet with one pull is map 5 on e85/100 octane. The sheet with multiple pulls has one with baseline run
Default 07-31-2017, 09:53 AM
they look the same to me..
Also your AFR is pretty high - you may want to try to get those trims lowered to see if AFR will drop above 4k rpm...
Car: 2017 BMW 340i
Default 07-31-2017, 02:35 PM
Totally posted the same sheet twice sorry about that.
Boostedf30 Boostedf30 is offline
Car: 340i
Default 08-01-2017, 08:58 AM
I have the same issue in my 340i for some reason jb4 does not like the octane so I am dropping timing.
Car: 2017 BMW 340i
Default 08-01-2017, 09:48 AM
I'm new to the whole tuning aspect. Would raising FOL accomplish that??
Car: 2017 BMW 340i
Default 08-01-2017, 09:51 AM
I can't post the video. If you have instagram, check out my profile the video of the exhaust is on there @bmwjon
Default 08-01-2017, 10:09 AM
Timing is an ongoing issue for many...
Within 10 minutes and two logs one will have great timing the other flat...
Something is afoot... especially on ign1... very often that is 0 for ...
I run 93 octane vshell (and tried others)
Very frustrating
Default 08-10-2017, 09:45 AM
Not sure why you are doing dyno runs in 3rd gear? It's hard to see much detail during a 4 second pull. But overall, log seems normal to me. In terms of timing it's going to do what it does. If you have timing issues your options are to lower boost, raise octane, and/or play with the IAT spoofing function.
Car: 2017 BMW 340i
Default 08-10-2017, 09:57 AM
Not sure why they did it at 3rd gear. Had it dyno'd at bimmerfest
