Snowman Snowman is offline
Car: BMW M135I
Default B58, JB4 and throttle closures? - 09-26-2018, 09:57 AM
I just picked up a used M140 and are trying to read up on the whole JB4 and throttle closure issue.
I found several threads from long ago describing the problem, but i have not been able to find any information that the problem has been fixed.
I have tried asking the question in the FAQ JB4 thats pinned up top, without any replies..
So am i simply better of waiting for MHD and other companies looking into the B58 or does the Jb4 work currently?
I have no interest in spending my money on a prototype that only makes the car run lumpy...
jrdoming jrdoming is offline
Default 09-26-2018, 01:36 PM
I have no throttle closure issues on map 1 or 2 but can't comment about map 3. From my reading the throttle closures tend to crop up with a p1pe installed.
2017 340i M Sport. JB4
JBoe JBoe is offline
Car: M240i
Default 09-26-2018, 09:04 PM
I only have them when boost spikes a bit, but that's OE design. Otherwise nothing. Stock, I had more closures than with the JB4 on any map 91 Octane could handle. Finally got octane and WMI installed. Now it's a beast and my logs can prove it.
Biggest issue is that the B58 is a tricky machine to tune. Stock DME does a lot to keep it engine safe. A little overly safe IMHO. JB4 cleared up a lot and fine tuning it allowed me to go further than I ever thought I would with this engine/car.
Default 09-29-2018, 09:19 AM
Throttle is largely misunderstood. But if you have a specific log we can tell you if you have normal behavior or abnormal behavior you'll want to correct with JB4 EWG adjustments.
Car: BMW M135I
Default 09-30-2018, 03:24 AM
I asked these questions because i was thinking of getting the JB4 and put it on the car.
However ive done some research now and there seems to be quite alot of reports of throttle closue issues when you combine JB4/tuning boxes and *****ted *********, which i intend of fitting.
So i will just wait for MHD to release their fix and stay away from JB4 at this point.
I have no intention of paying lots of money on a unit that causes my car to run jerky.
Default 09-30-2018, 09:47 AM
So you don't have a JB4 yet nor a log of how your specific car is running but want me to provide you with "hypothetical" JB4 tuning advice? Generally, if running exhaust modifications you'll need to set FUA = 20 to offset dutycycle causing boost to go over target and corresponding excessive throttle closure.
In my testing the exhaust mods added zero power or benefit, I would not suggest them in most situations, whether tuning with JB4, flash tuning, or both.
Default 09-30-2018, 12:30 PM
Terry is there ever a point where you *need* to modify your pipe/exhaust due to concern over exhaust gas temp etc? Much like the stage 2 "tunes" saying you need some type of aftermarket ******** to run them long term.
Nugs Nugs is offline
Car: 2011 135i
Default 09-30-2018, 07:02 PM
I'm running a "stage 2" flash tune and a ** only got me an extra 10whp.
But I figure the reduced back pressure is better for the engine and turbo long term.
I have no data to back that up though.
Car: BMW M135I
Default 09-30-2018, 12:58 PM
Yes i was interested in peoples general opinion with Jb4 and the B58 platform, perhaps im the only one that wants to know what to expect before buying this?
Or is that why there seems to be reviews or basicly every product available to purchase?
I'm not interested in power benefits with the *****, i want the added sound and a car that performs as before. So if adding a Jb4 would make the car run jerky, i would not be interested in it...
Had no idea that asking for opinions and peoples experience would be considered such a strange question
Car: M240i
Default 09-30-2018, 08:39 PM
I've been reading these boards for a bit now and haven't seen the issues you're referring to in any except when:
1) Users try to jump to higher maps without octane/fuel to support it.
2) Users don't have default settings prior to using the unit.
3) Users try to tune their car without posting logs for help and don't listen when help is provided.
4) Users don't allow FF to fully learn.
5) OBD cable issues.
6) User install issues and/or connector issues.
7) Rare few have had an issue with older boards. BMS provided free replacements in each instance I've read about.
After all that, what you tend to see are user issues. If you want a slap it on and go box... get JB+. You still have to let DME learn a bit, but user error side is removed if installed properly. If you want the most you can get, you'll need to tune.
That's what JB4 offers. It just happens to give you a few starting maps to build off of and from there you need to tune it in for more. This forum/BMS offer some of the best support I've ever seen for FREE! I've been building cars and tuning for years with Split Second, AEM, Emanage, Holley, Fast, etc. None of them offer map/log reviews and support for free.
It seems more like you came on the site with a negative agenda and nothing was going to change that. In the end, intentional or not, that's how it's coming off. It's your money and choice. My advice would be not to discredit the JB4 until you've actually tried it. Instead, ask your questions... get your answers... say thanks and move on. Complaining about something you haven't even tried, goes back to childish notions that benefit no one.
Bullitt1841's Avatar
Default 09-29-2018, 05:45 PM
JB4 with EWG wires give you incredible amounts of control over the tuning and it's very easy to get rid of any throttle issues that may show up.
bavarianmw bavarianmw is offline
Car: 17 320i, 16 M3 (outgoing), 18 340i (incoming)
Default 09-30-2018, 10:09 AM
Hey bullitt, do you mind looking at the logs / questions in my post history? I have a feeling I can get my p1pe setup tuned in better with the "control" you speak of, just I do not know what to try. It's already running pretty well on 11test, map 6, 16 lbs but I wonder if it could be even better. Only thing I've changed is FUA 10, just saw Terry suggested 20. Might try that.
Default 09-30-2018, 07:23 AM
Did you not read my post?
Car: BMW M135I
Default 09-30-2018, 01:01 PM
Oh yes i did.
However i've done some research now and there are more people with JB4 with or without dec@t that are experiencing jerky/lumpy power delivery during WOT than people with positive experiences.
So at this point im staying clear of JB4 until the results seem to be more clear.
The guy i bought the car from even had tried a JB4 on the M140 and the same unit on a 440i and a 320 B48, all cars behaved strangely with jerky power output during WOT.
I have no intention on forking out 600-700usd on something that makes the car worse. Im sure it will be resolved in the future, but until that point im staying away.
Default 10-04-2018, 03:30 PM
You need a serious attitude adjustment if you want people to listen to you here. This is not E90post.
Car: M240i
Default 10-05-2018, 05:30 PM
Thank you, sir. He kinda proved my point. It's unfortunate written correspondence tends to reflect the reader's emotional take. I didn't mean to offend... only advise how it read. Again... my take on his words. Sometimes I just shouldn't post. Lol.
Default 10-04-2018, 04:29 PM
If you add in a d@wnpipe the stock tuning will not be as smooth. You can mostly tune that out with a JB4 + EWG connection. My advice, just skip the d@wnpipe all together. As to the JB4 it's easy to try. If you're not happy with it then return it or resell it and move on to the next option. But coming in and trying to lecture guys here (myself included) who drive and tune B58s daily, seems like a waste of everyone's time.
jbourne jbourne is offline
Car: F30 320i B48
Default 10-04-2018, 09:24 PM
uh oh,, so, I own 320i B48, does adding a custom c@tless d@wnpipe is a bad idea? i've been using both (jb4 + custom c@tless d@wnpipe) on map3 since the beginning.. can you please clarify on this?
Default 10-05-2018, 11:02 AM
With the B48 the gains are probably lower than the B58, which are already really tiny. But if you need tuning help post a log and we'll help you sort it. Using the EWG connector you can easily tune out throttle closure from exhaust mods.
Car: F30 320i B48
Default 10-05-2018, 06:11 PM
okay, gonna make log and post later, see if i'm gonna need EWG after. thanks Terry.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 10-05-2018, 09:40 AM
i have a CG c@tted and never experience throttle closures. I know the c@tless experience this more and it can be adjusted with the EWG pigtail.
| M-Performance exhaust | VRSF | BMS intake | JB4 | 100% Meth Injected |
kyleralph078 kyleralph078 is offline
Car: bmw m140i
Default 10-16-2018, 11:28 AM
sorry to hijack the post but I'm just wondering if anyone could log at some logs? I'm having some issues and just curious if its something obvious I've done or some settings to change? not on here to badmouth or be negative just genuinely need some help here. any help/advice is greatly appreciated.
kind regards
kyle
dRDiesel's Avatar
Car: BMW
Default 10-17-2018, 09:09 AM
kind regards
kyle
You can make a thread and post the logs here and someone will get back to you quicker rather then in here: https://www.n54tech.com/forums/forumdisplay.php?f=46
