Wickedowesix's Avatar
Car: 540i G30
Default B58 e30 + meth - 04-17-2018, 07:22 PM
Anyone else with B58 running ethanol (91 + e30) with 100% meth with good afr amd trims?.... My car loves the combo!
Don_diddy Don_diddy is offline
Car: 340ix
Default 04-19-2018, 05:40 PM
Im running (93+e30) with meth additive 5 and i like it. i felt as if e30 helped it run a bit smoother on my end with meth.
6mt 340ix with Bms intake , vrsf dwnpipe , meth , jb4, straight pipe, ewg and ff wires.
Car: 540i G30
Default 04-19-2018, 06:34 PM
Yeah same here.... I'm at 65 additive
Bullitt1841's Avatar
Default 04-21-2018, 11:32 AM
5 or 50 additive?
Car: 340ix
Default 04-21-2018, 12:31 PM
5 additive once i shift additive to 10 or higher i witness throttle cuts... my car literally doesnt let me pass about 15 psi under any adjustments
Default 04-21-2018, 04:31 PM
I'm still not understanding what you're saying. Are you entering a value of 5 or 50 in the meth boost additive field? A value of 5 is equivalent to only 0.5 PSI.
Car: 340ix
Default 04-21-2018, 10:12 PM
A value of 5 aka 0.5psi added
Default 04-22-2018, 10:24 AM
If you're only able to run 0.5 extra PSI with E30 and meth, you have some major tuning issues.
Got any logs?
Car: 340ix
Default 04-22-2018, 12:20 PM
Id be willing to pay you a great deal if youd fix it remotely or whatever
Car: 340ix
Default 04-22-2018, 12:43 PM
Or if you have family in ny id honestly be willing to pay for the plane ticket at this point. Im this close -><- to getting massive camber and stretched tires lol
Default 04-22-2018, 05:47 PM
Terry is the best at giving advice on the B58 platform. I only know small bits of info here and there. But he actually writes the code for the JB4.
Snirre77's Avatar
Snirre77 Snirre77 is offline
Car: Bmw M140i
Default 04-23-2018, 12:12 AM
Hi i am running 95 + e20 with 100% meth with 45 additive and it runs strong. Boost and timing looks good but trims go below 10 so still looking around that
Car: 540i G30
Default 07-08-2018, 06:43 PM
Update:
Currently on e40 now and car loves it
17' 540i
Jb4
Deepee
E40
100% meth 40 add
Side note last nite i raped a M5 v10 from a 60 roll
Default 07-09-2018, 09:45 AM
Originally Posted by Wickedowesix
Update:
17' 540i
Jb4
Deepee
E40
100% meth 40 add
Yes, the methanol really opens these cars up! Got any logs so we can see how she's doing?
Car: 540i G30
Default 07-09-2018, 10:26 AM
Here is a log
Default 07-09-2018, 11:13 AM
Here is a log
Looks pretty good!
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 08-04-2018, 08:03 AM
I pumped 3 gallons of E85 yesterday for the first time and fully topped my tank with 91 octane. I can feel a difference the car does like it and the only mods i have is the BMS intake, CG 5" catted **, and MPE.... no JB4 or flash tune.
|2018 BMW 340i|M-sport|Track Pack|
|M-Performance exhaust|VRSF|BMS intake|JB4|BMS Meth kit Dual BM7 nozzles|
Car: 540i G30
Default 08-26-2018, 08:13 PM
Update
Currently on e50, dual CM7 100% meth, 40 additive
Here is a 5th gear pull log
Default 08-27-2018, 10:24 AM
Update
Woah, really clean looking logs man! I be the car pulls like a monster, no more fueling issues either .
BMW After BMW
Car: BMW M240i
Default 08-27-2018, 12:42 PM
Update
Is your only bolt-on that p1pe you mentioned? That is some good stuff there, for a basically stock car, if so.
I am on e20, 50/50 water/meth and additive 40 and having the stuttering /closures or misfiring (still not sure which it is) others have mentioned. At additive 30 all is well, but obviously I don't get the same power numbers you show at 40. I have seen a lot of split opinions on whether to keep the 50/50 mix or go 100% meth (safety concerns), as well as debates about nozzle size. My nozzles are the same size as yours.
Want to get to where you are. What are your other meth values for min/max RPM and your min flow boost? Have you modified any other meth values (trigger, etc?)
2017 F23/M240i Convertible (B58) / 6MT / FF Wires / EWG Wires / BMS Air Intake / Stock Exhaust / BMS Meth (50%) / 93 Octane
Car: 540i G30
Default 08-27-2018, 05:39 PM
I'd honestly do staight 100% meth. I have meth trigger at 8psi.
BMW After BMW
Car: BMW M240i
Default 08-28-2018, 07:33 AM
Thanks for replying. Looks like your settings are similar (save for meth mixture). I'll wait to see what support says as well but your #s look very promising.
dRDiesel's Avatar
Car: BMW
Default 10-19-2018, 05:11 PM
Im 1 click away from meth I keep going back and forward with it. Someone convince me.
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 10-19-2018, 06:14 PM
All we want is e40.
2016 340i M-Sport |JB4|ER DNPIPE|BMS Intake|
Default 08-27-2018, 01:38 PM
Update
Stock flash, still?
