(#901)
Default 03-25-2020, 05:35 PM
Originally Posted by khalidss
Can you check my log please. 98 Octane, Map5, C43
intake + down-pipe
speed: 60-115 Mph
Looks good to me!
Default 03-25-2020, 05:37 PM
Originally Posted by aussie644
Bumped my map back up to Map5 and things don't look so hot IMO.
1) It looks like the engine is running really lean on the 0-60 pulls, especially in 1st gear.
2) I'm also getting boost cut between 1st and 2nd and ignition spikes way up (about 25, unusual)
3) Everything just looks a little wonky.
Running E33 with the green wire hooked up.
AFR and fuel trims look good. On the 1st->2nd looks like boost is going over target a touch or its over-revving a touch. Try setting 1st gear to 2psi to see if reducing boost at the launch helps that.
aussie644 aussie644 is offline
Car: W205 C43 2017
Default 03-25-2020, 08:03 PM
Terry, thanks for the quick response. Not positive what you mean by setting 1st gear to 2psi, AFIK we don't have boost by gear for c43 yet?
If I ramp up boost slower b/w 0-4k RPM could that help (since only 1st gear used that RPM range generally)? Also, are Map 6 values initially the same as Map 5? (I'm sure this has been answered somewhere)
Car: W205 C43 2017
Default 03-26-2020, 12:02 PM
Although I do see "Max Boost 1st (0 Disables)" in the JB4 app settings now which I don't think was there prior to the update (or I just never noticed it). Is this enabled on the C43?
Also, I answered my questions about Map 5&6. Map 5 is far more aggressive than default Map 6
*** Update ***
After digging around I found in the C63 section there was a mention of this "boost by gear" type behavior. Couple issues. One, unlike the description in the C63 section it does not reduce the PSI by the value it's set to, but as its label implies, it limits the boost target to that amount. So I tried '1' and instead of my target being 6 (7 - 1) it was 1..
More importantly, the boost by gear works off the MPH parameter which unfortunately is calibrated I believe for either the 7 gear trans in the C63 and C450's, or to 18-inch wheels (likely the former).
Either way, my PSI is limited partially into 2nd (9G-Tronic and 19 inch wheels, 1st ends around 22MPH, 2nd around 44, and 3rd at about 65, decently off what this is calibrated at).
Could you guys not add some logic that looks at MPH and RPM to determine gear? Or possibly allow users to indicate their vehicle?
Happy to bring my C43 in if it helps (obviously lockdown is done)
