(#2726)
Manchuz Manchuz is offline
Car: 2018 Kia Stinger GT Ltd
Default 10-11-2019, 08:56 AM
Originally Posted by Manchuz
Hello, new member here and new owner of JB4. Can you kindly look at my map 1 readings and see if they're fine.
Dumb question, but how do you know if you've installed the fuel wires correctly? Can you see it in the readings? I installed the plug and play cables and did a bit of hack and slash job on the wires to add quick disconnects.
|Denso @ 0.022|CAI|91 octane|v11_3|not sure what my elevation is
Default 10-11-2019, 09:43 AM
Originally Posted by atr1
Indeed I tried to disable it and it didn't work.
(I panicked and reverted to version 9 lol)
Then you'll have to redo all your settings again for the scaling change.
Default 10-11-2019, 09:44 AM
Log looks OK. You can check the fuel wire performance via the fuel trims. If they are dropping as fuel enrichment goes up, and relatively close together, your fuel wires are working properly.
Thumbs up 10-11-2019, 01:42 PM
Awesome, thanks!
kcranmer kcranmer is offline
Car: 2020 Kia Forte GT
Default 10-16-2019, 02:17 PM
Yes or swapping them. On the 4bangers the plugs are easy to reach.
Finally got the cable and upgraded to v11. In reference to Atr1's experience upgrading, is there anything else I need to do after the upgrade? I am only using Map 1.
Also, I want to confirm it has seemed to smooth out the idle. I did notice when revving the engine up it occasionally has a pop when I lift off the gas. I haven't gapped the stock plugs yet because I don't know the torque needed when putting them back in. So that leaves me with 3 questions. Do you think the pop is coming from the plugs not being gapped properly? Does anyone know what torque is needed on a 1.6L Turbo? Finally, I wanted to leave the data cable plugged into the JB4 and run the cable through the fire wall into the cabin of the car but the case is not capable of closing due to a piece of metal in the top half of the housing hitting the connector of the data cable. Is the case not designed to keep the data cable plugged in?
2020 Kia Forte GT
JB4 Map 1
Default 10-16-2019, 09:26 PM
You remove the shell on the data cable to mount it in the box, see video:
JB4 Mobile How To - YouTube
Default 10-17-2019, 04:28 AM
Shoot, I forgot that was in the video. I watched it before I got the cable and should have watched it again I guess. Thanks.
2020 Kia Forte GT
JB4 Map 1
djerickd djerickd is offline
Car: 2019 GTS
Default 10-17-2019, 07:25 AM
Hey Terry I noticed mine doesn't display some of the guages like, trans temp, gear, oil temp. Is it supposed to??
Default 10-17-2019, 08:17 AM
It's normal as not all parameters are connected to the Q50
suwon5788 suwon5788 is offline
Car: stinger
Default hybrid turbo system. - 10-19-2019, 09:42 PM
hi terry
when launching?
and..
how much?
TerdBath TerdBath is offline
Car: G70 3.3
Default 10-20-2019, 11:41 AM
Does the bit7 “on” work with any map? Currently running map 2 on 3.3 g70 AWD.
Default 10-20-2019, 08:54 PM
Originally Posted by suwon5788
hi terry
when launching?
and..
how much?
It's not a BMS product. Check with Pure Turbos for their Stinger offerings.
Yes the option is global for all maps.
Car: G70 3.3
Default 10-21-2019, 06:56 AM
Good to know Terry. In the WRX world the Accessport did something similar. That turbo 4 would lag down low then all of a sudden give 100% turbo mid turn when merging into traffic from a stop. The Accessport changed the turbo delivery to make it more predictable/linear. I'm still in the break in period so have taken it easy so far with the G70. Only 100 more miles before I can really start playing around.
FlooF FlooF is offline
Car: Genesis G70 3.3T
Default Just Wow! The JB4 Tuner is Awesome - 10-21-2019, 06:42 PM
Good Evening Terry,
Thank you for developing such a wonderful tool.
I have attached my logs of my most recent run and was curious to your opinion.
I have the BMS intake and JB4 running on Map2. Ambient temperature was 82F and humidity was about 95%.
My best 0-60 times are about 4.7 Seconds.
Default 10-21-2019, 08:40 PM
Break in? Bah!
Originally Posted by FlooF
Good Evening Terry,
Looks good to me!
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
GermanI30N
