Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default Dyno run today! - 05-11-2013, 03:36 PM
got a chance to run on the dyno today. had 3 pulls but the first two where map 5 and where damn near the same. so the photo shows map5 and stock.
mods jb4 g5 iso bms dci custom chargepipe synapsebov. and 7gallons of e85 rest 91
pretty damn good!
Car: 07 E90 335i
Default 05-11-2013, 03:41 PM
pdf of dyno and csv file attached
Default 05-11-2013, 03:45 PM
Looks good. Definitely more power in there with a stronger mix.
Car: 07 E90 335i
Default 05-11-2013, 03:56 PM
i agree. stuffs awesome. ********* im sure will bump me to 400 ish :D
busky2k's Avatar
busky2k busky2k is offline
Default 05-11-2013, 09:55 PM
Looks great. Trims are good. It knocked a lil @6000rpm but it was past your power peak anyway. I would have thought 7 gal of E85 would have been enough to have a knock free run!
Car: 07 E90 335i
Default 05-11-2013, 10:13 PM
Youd think but I think maybe because I'm running factory plugs and I'm at 65k miles . Wanna get ngks I missfire every so often . But it was fun my first dyno. Ever :D
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 05-12-2013, 04:35 AM
Time for Meth!
Car: 07 E90 335i
Default 05-12-2013, 10:04 AM
I'm gonna go for ********* first then maybe meth. Or bms flash
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 05-20-2013, 10:05 PM
So basicly you have determined knocking by throtle lose from the log or something else ?
busky2k's Avatar
Default 05-21-2013, 04:41 AM
Generally there will be an abrupt drop in ignition timing accompanied by an increase in avgign. It may drop 1-3 degrees and avg ignition will rise by 0.5-1. It varies from car to car, depending on how severe the DME perceives knock.
Taron's Avatar
Car: 2008 BMW 335XI
Default 05-24-2013, 08:47 AM
Thanks for info But what about drops on gear changes.
I see from logs on my car that I have timing drops on all gear changes is that ok?
