N54Boost N54Boost is offline
Car: 07 335i N54
Default New to JB4 - 05-30-2013, 10:48 AM
Ok, so ill admit im rather new to the JB4. So before i install it, i have a few questions. Should i install the ********* ** first then the JB4 or does it even matter? Also once the JB4 is installed, ill need to hook it up to my laptop to download the latest firmware correct? And would you guys/girls recommend me snipin the diodes now before i install?
i know im a NOOB but id greatly appreciate the advice
thanks guys
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 05-30-2013, 11:04 AM
Doesn't matter, all roads lead to the same outcome. If it was my first time I'd probably install it the way I got it to make sure it works after wired in including laptop communication, and before I put everything back together pull the cover off, snip snip, and upload firmware. You can put the **'s on whenever you feel like it, I had to reset adaptations afterwards so probably after the jb4 is best.
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 05-30-2013, 11:09 AM
I would snip, then just plug and play! Set it too map 5, do a couple of 3-4 full throttle runs (ie "wot") and then enjoy!
537.75HP 540.63TQ
Car: 07 335i N54
Default Thanks - 05-30-2013, 11:17 AM
Hey guys i really appreciate the response, Thanks Alot
scotte30m3 scotte30m3 is offline
Car: 07 335i sedan
Default 05-30-2013, 12:30 PM
Along the Lines of the **... Are there specific setting that need to be changed after the *** are installed to eliminate the rear O2 sensors?
