Car: 2014 335i M-Sport
Default AMG Health Check - Logs Attached - 09-17-2019, 10:26 AM
Please review my logs. Map 2. 93 octane in tank. Thanks
2018 C63s AMG
JB4 E30, Pedal Tuner
Default 09-19-2019, 06:55 AM
bump
2018 C63s AMG
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 09-20-2019, 08:12 AM
overall looks good. was this 3rd gear right? try a log in 4th too.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Default 09-20-2019, 11:49 AM
I don't see any issues here.
Default 10-02-2019, 08:02 PM
I have 4 logs, 3rd and 4th gear with two runs each. Each file name has the gear selection included. Please review and let me know if I need to make any changes in the settings. I had 3.5 gallons of E85 and the rest 11.5 gallons 93 octane in the tank. Thanks.
2018 C63s AMG
Default 10-03-2019, 01:21 PM
bump.
2018 C63s AMG
Default 10-04-2019, 10:14 AM
Trims are sort of maxed out. Raise FOL to 40 and get another log.
Default 10-04-2019, 10:17 AM
Roger that!
2018 C63s AMG
Default 10-08-2019, 07:10 AM
Raised FOL to 40. Logs attached for review. Thanks.
2018 C63s AMG
Default 10-09-2019, 04:39 PM
bump
2018 C63s AMG
Default 10-10-2019, 10:46 AM
Much better, looks good to me
LessIsMore's Avatar
Inner Circle Member
Default 10-10-2019, 05:04 PM
From 4500 to 5000 rpm the trims are still maxing out just like the first log. That seems to correspond with a slower rpm acceleration over the same rev range.
Payam or Terry, is that mid range trim max something that could be improved upon?
I 've seen it in some of my logs as well.
2017 AMG C63 -JB4
Default 10-11-2019, 01:46 PM
It's based off RPM, more fuel at more RPM. That's why you see it start dropping as RPM rises.
Default 10-12-2019, 08:33 PM
Thanks Payam. I'll leave it here for now and enjoy my car. I'll look into the BCM next with WMI and the intakes. Its just that with the pedal tuner in stage 1 maxed, traction is as rare as gold especially in 1st and 2nd gear. This car is insane!
2018 C63s AMG
Default 10-15-2019, 01:37 PM
Time for stickier tires!! The intake is a huge difference, go for that one next IMO
Default 10-22-2019, 09:27 AM
Roger that! No CEL with the intakes right? I had an issue with MAF readings throwing a CEL with aftermarket intake.
2018 C63s AMG
Default 10-22-2019, 04:11 PM
Correct, no CEL. These cars are MAFless, no need to worry
