(#301)
Jhoye66 Jhoye66 is offline
Car: Maserati ghibli sq4
Default 05-04-2020, 10:45 AM
Got it all working. Running Map 2 at the moment. Next fill up will do 4 gallons of e85 and then on to Map 5
Brandontwalker Brandontwalker is offline
Car: Maserati Ghibli
Default 05-12-2020, 06:48 AM
Use the file on the first page of this thread.
I have been running the new tune for a couple of weeks now. When in map 1 or 2, the turbos appear to be thrown offline within 5 minutes of driving. CEL follows with code 0209 (low boost). Currently back to running map 0. Any recommendations?
jvalen3003 jvalen3003 is offline
Car: 2014 Maserati Ghibli SQ4
Default 05-12-2020, 07:07 AM
Hey bro check your code again. Are you sure it's not code P0299? That code was giving me the CEL multiple times
Default 05-12-2020, 07:24 AM
You are correct. It is 0299.
Default 05-12-2020, 10:19 AM
It happens randomly or do you think something is triggering it?
You're on the latest firmware, right?
Default 05-12-2020, 10:22 AM
Payam, how can I upload the latest firmware?
Default 05-12-2020, 10:54 AM
It never happened before downloading the latest firmware the other day. Now, it throws turbos offline in map 1, 2, and 5. I pasted a log below (never mind. Pasting the log didnít seem to work)
Default 05-12-2020, 11:14 AM
[QUOTE=Brandontwalker;665238]It never happened before downloading the latest firmware the other day. Now, it throws turbos offline in map 1, 2, and 5. Recent log is attached.
Default 05-12-2020, 11:22 AM
There's a new firmware?
Default 05-12-2020, 07:32 PM
[QUOTE=Brandontwalker;665240]
Code just means car thinks you have a boost leak. Sure it comes up if leaving the JB4 on map1?
Default 05-13-2020, 09:18 AM
[QUOTE=Terry @ BMS;665288]
Positive. I can set the JB4 to map 0, turn the car off and on, and all functionality is restored.
Default 05-13-2020, 10:09 AM
[QUOTE=Brandontwalker;665327]
Here is a log from a rather easy run down the interstate in map 1 just a moment ago.
