(#301)
overboos overboos is offline
Car: c63
Default 08-09-2020, 05:24 PM
Do you guys know what code 2279 and 152c are?
I’ve had that code come up several times now and I can’t find any info on it. It’s usually in the morning when I first start the car. Shortly after the first start it will start misfiring and run rough, then when I restart the car those codes pop up. Once cleared the misfires go away and I won’t get the codes for a few weeks. I want to say it happens every time I fill up with 93 + e85 blend but can’t say for sure. Any one else with those codes?
BimmerFan BimmerFan is offline
Car: 2014 335i M-Sport
Default 08-14-2020, 01:50 PM
I have the same issue. Google search reveals Vacuum leak, PCV Valve or hose cracked or leaking which highly doubt. I really have no idea. I am really starting to think our cars don't like E85. When I run 93 octane only for a bit. All is well, till I put e30 in the tank, then CELs stream in along with rough idle and performance. Really strange.
2018 C63s AMG
JB4 E30, Pedal Tuner
Default 08-14-2020, 02:34 PM
E85 with the platform is hit and miss. Creates a lot more stress on the fuel system and to a lesser degree plugs. If it's causing issues just keep lowering the mixture until they stop.
Default 08-16-2020, 03:14 PM
What is the recommended spark plug and gaping for this platform? A tech from Weistec recommended the NGK SILZKBR8D8S Iridium Spark Plug and stated although for BMW works great on the C63s. Any thoughts? Should I just replace with OEM original plugs from Mercedes?
2018 C63s AMG
Default 08-17-2020, 02:57 PM
On the plugs OEM are fine but close the gap down to 0.020 - 0.022".
Default 08-18-2020, 07:45 AM
Thank you.
2018 C63s AMG
chiptherip303 chiptherip303 is offline
Car: 2016 c63s
Default E85 Mixtures? - 09-08-2020, 11:27 AM
Hey guys!
New to forum. Recently purchased a 2016 c63s. Through a catback exhaust and k&n filters on and expecting the JB4 tuner soon. Curious what are the recommended tunes for E85 mixtures and what are the exact mixtures for what tune?
Looks like there's a map for 30% E85?
Is there map/tune to run full E85? Is that possible with stock fuel pumps/injectors?
Default 09-08-2020, 02:40 PM
The most you can run is around a 30% mix, but fuel pressure can be an issue. I'd start with 20-30%, map2, and log to evaluate it.
Kb_Photogs Kb_Photogs is offline
Car: C63 AMG
Default 09-18-2020, 02:18 PM
Hello.
Has anybody had an issue where installing Jb4 on 2019 C63 AMG caused active brake assists functions to be disabled/limited including active suspension faults?
Had new wheels, *********, and JB4 installed. I don't see how the first two could have anything to do with something electronic.
Any ideas?
Default 09-19-2020, 08:44 AM
You can unplug OBDII and remove it off the CANbus all together for testing but don't see how it could be related. Seems more likely something was knocked loose during the wheel/exhaust work.
Car: C63 AMG
Default 09-19-2020, 08:46 AM
To confirm, JB4 had nothing to do with it.
Took it to Mercedes this morning is it was a fault clock spring.
I'll be shooting over logs to you after this Tuesday.
It's a 2019 C63 so it has the new 9 speed.
Default 09-19-2020, 04:36 PM
Easy fix
Car: 2016 c63s
Default 10-05-2020, 01:35 PM
Has anyone purchased and ran the WMI kit?
If so did you run the car and or put it on a dyno?
If so what were the results?
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-20-2020, 02:04 PM
Terry, can you elaborate on this? What issues and at what ethanol %, which maps, etc.
When you say stress, are you referring to high fuel trims or are there specific mechanical components you have observed? I just like to know what to look for.
FWIW I personally have had great success with E85 on this platform. I run it every day on map 4, for a year. Usually at 25% mix. I have never had a error code or miss fire related. I did do a lot of data logging and Review of the logs when I 1st set it up to make sure there were no problems. I had noticed that when you get to 30% ethanol, the trims start getting really high and/or maxing out on.maps 4 and 5. I would not recommend going quite to 30% on thise maps based on my experience, that looked like the ragged edge of the fuel systems capability to deliver enough volume.
jagger230 jagger230 is offline
Car: Volkswagen GOLF R
Default 11-02-2020, 12:29 PM
hey guys so i take the E63S to the dealer they changed timing chain and problem was solved without the jb4 in it. the car is misfiring with the jb4 constantly ive had the issue in my friends c63 and glc 63 and now the E63 ive replaced circuit bords several times and the car is still doing it.... please help.... ive also changed gapped spark plugs and gapped them to 0.020
Default 11-20-2020, 12:40 PM
The fuel pump just can't keep up on all models. E30 works great for some, on others even E20 causes a fuel pressure drop. So it just comes down to being case by case. In most cases E30 map2 for example will work fine.
Default 11-20-2020, 12:41 PM
Whatever is going on there is beyond what we can provide with JB4 support, sorry.
rowdytn rowdytn is offline
Car: 2019 GLC63 AMG
Default Current Maps for GLC63 - 11-20-2020, 04:43 PM
It seems the maps have changed since they were first posted in this forum versus the instructions currently shown on the Burger Tuning website. Can someone please confirm what the current maps are? i don't want to put the car in "valet" map and accidentally pick a map that is expecting racing fuel or something.
Default 11-21-2020, 08:40 PM
Map8 is the VALET map.
hfraj's Avatar
hfraj hfraj is offline
Car: 2008 BMW 335i Sedan
Default 01-01-2021, 08:09 PM
Are there any plans to add steering wheel controls to this platform?
Default 01-02-2021, 10:48 AM
Nothing imminent. We've looked in to it but until we have full dash commands not a lot to be done. The app provides a nice real time interface though and is easy to use.
