(#226)
aardwolf2 aardwolf2 is offline
Car: Golf R
Default JB4 firmware update fails - 02-24-2019, 05:12 AM
Hi, new JB4 user here so please let me know if I'm doing something stupid. Fitted yesterday to my 2004 Golf R, took the car for a run to clear all of the error codes and all was fine, so I decided to update the JB4 to the latest firmware, and it failed at 238 of 311, it tried 5 times before giving up, each time the same error "Error uploading". I was using the mobile app from android via bluetooth, so this morning I swapped in the usb lead and tried from a win10 laptop, and it got stuck in a never ending loop of failing at 238 of 331, I tried JB4_VW_8_4 and VW_JB4_OBDII_8_T3. I've searched the forum but can't find anyone else with the same error. Unfortunately the screenshot I took when connected that showed a firmware version number hasn't saved I've had to strip out the JB4 as I need to use the car and connecting to it gave me the error that it didn't have any firmware and the car wouldn't run without any. Was wandering if anyone had seen this before and managed to fix it?
The JB4 pcb silkscreen says G3 v2.
Thanks for any replies.
Default 02-24-2019, 06:13 AM
The circuit board is for a JB1 so the firmware that is here should be loaded to it: https://www.n54tech.com/forums/showthread.php?t=34711
Car: Golf R
Default 02-24-2019, 06:44 AM
Bother, clicked the wrong button at checkout, oh well, lets see what a JB1 can do. Many thanks for the quick reply, I'll refit next weekend and give it a go.
Default 02-24-2019, 06:59 AM
Drop me a email at george@burgertuning.com . There is a chance you will need to do a disaster recovery procedure if it wont let you connect.
julian2292 julian2292 is offline
Car: bmw 1m
Default 02-24-2019, 12:30 PM
Probably this week coming.
Please also map 1+
for 91 octane users outside US.
30thedition 30thedition is offline
Car: 2014 vw gli
Default jb4 - 02-24-2019, 05:21 PM
hey george i have a 2014 gli unitronic stage 2 with the jb4 stack i recently purchased a new board from you guys cause i bricked the old one i had a polar fis system hooked up with the jb4 and i confused it installed new board and it was working fine until friday i was on map 6 and changed some of my fields and now i cannot get it to work it only shows map i'm on and boost all other fields empty i updated the firmware and i tried to the basic settings reset but im alittle confused , i'm assuming i am redoing the basic settings on map 6 thanks kyle
Default 02-24-2019, 05:25 PM
Originally Posted by 30thedition
hey george i have a 2014 gli unitronic stage 2 with the jb4 stack i recently purchased a new board from you guys yesterday cause i bricked the old one i was on map 6 and changed some of my fields and now i cannot get it to work it only shows map i'm on and boost all other fields empty i tried to the basic settings reset but im alittle confused , i'm assuming i and redoing the basic settings on map 6 thanks kyle
Go to user adjustments and make the Future use D value 1 and save. Lock the car so the JB4 can power down and data should start streaming.
antsh antsh is offline
Car: B9 A4
Default 02-25-2019, 11:05 AM
Originally Posted by julian2292
Please also map 1+
Or a recommendation to try try for MAP 6 to achieve the same. Yay for California 91 gas.
As an aside, any chance for development of a meth system for the A4? I know the S4 guys are getting one. Everything should be the same (tank, lines, etc) except for the throttle body adapter.
jagger230 jagger230 is offline
Car: Volkswagen GOLF R
Default car play with jb4 - 02-25-2019, 03:18 PM
any success w jb4 working w car play
Default 02-25-2019, 03:27 PM
No chance yet without jail breaking the phone and using carbridge app.
Car: 2014 vw gli
Default 02-26-2019, 04:56 PM
hey george tried what you said and its still not working , only shows map and boost , can i send it back to burger tuning and have them reset it ?
Default 02-26-2019, 06:17 PM
Did you lock the car for a while so the JB4 can power down for the FUD setting change to take affect. Is it easy to disconnect the Polar FIS as it could be causing issue with the OBD data stream. Best also to get hold of me via email for a quicker resolution. george@burgertuning.com
Car: 2014 vw gli
Default jb4 fixed - 02-28-2019, 07:29 PM
Hey george got my jb4 working today i had a brain fart , i changed future use d to bit 1 and saved it locked my car and tried it this morning and its working correctly thanks for the help i'm going to be install water meth soon and will need help with the tuning aspect of it i'm going to use the jb4 water meth controller you guys have well thanks again for the help kyle
Default 03-01-2019, 08:23 AM
For guys reading the GLI and Passat/Jetta/Beetle 1.8T need to have the FUD set to 1.
Cr50 Cr50 is offline
Car: Mk6 Jetta
Default 03-03-2019, 11:56 AM
I have a 1.8 gen 3 6 speed auto, should I have the boost redux set to anything? Also I get some hesitation on the freeway at cruising speeds with low throttle input
Default 03-03-2019, 12:54 PM
We have never needed to use it.
Check to see what firmware version you have in the user adjustment page and post it here.
Car: Mk6 Jetta
Default 03-03-2019, 12:56 PM
VW_JB4_OBDII_7_TEST4
Default 03-04-2019, 04:22 AM
Roll it back to the attached firmware and lets see if it feels better.
Default Golf r 2016 - 03-04-2019, 05:09 AM
hey george, wondering if you can show me dynos w a golf r with 94 octane jb4 map 6, intercooler and intake and ********
thanks
Car: bmw 1m
Default 03-04-2019, 08:03 AM
Hi George.
That was last week
Can you post the update pleasee
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 03-04-2019, 01:18 PM
Probably they have reason to hold update...
I use latest fw and work ok(smooth and powerfull) I hope that new fw will bring some new fetaures(like oil/trans temperature in logs)...
Car: Mk6 Jetta
Default 03-04-2019, 02:19 PM
Will do thanks!
nebulein nebulein is offline
Car: Leon Cupra 300
Default 03-07-2019, 07:12 AM
Could be a leaky valve although the boost isn't considered very aggressive.
I fixed it, the screw from my turbo inlet was loose
Now the car works perfect, big thanks for your help.
andrew626 andrew626 is offline
Car: golf r
Default 03-08-2019, 03:08 PM
Hi George.
That was last week
x2!
yess please. need map1+ for daily and map2+ for my drag racing event in two weeks.
audio vicious audio vicious is offline
Car: '17 GTI Sport DSG
Default 03-14-2019, 06:10 PM
I'm running a JB4 and looking into a catted ********. I have to pass emissions in my state yearly. Luckily, I just did, so I've got a whole year before next inspection.
What I'm wondering is what to expect from the ******** with the JB4. I'm not concerned about overboosting since the JB4 has the boost safety value. I don't want to stare at a CEL all the time though, assuming that the spacer doesn't work (I've read mixed results). I know you can use Future Use D at 90 and it'll clear the code, but I'm concerned about it clearing codes I may want to be aware of. Then again, if the CEL is just on all the time and I assume it's the ********, it could also be something else I should be aware of that I mistake for the ********.
Wanting to pick one up soon, but was hoping someone could weigh in on this for me. What are my options? Thanks in advance.
