(#251)
thelostrican thelostrican is offline
Car: raptor
Default 08-09-2018, 10:39 AM
What are the specific codes? We've tested remote start with our development car without issue. Also try loading latest firmware to see if it makes any difference.
Codes are p0108 and p0238.
I just got them with the new firmware, I didnít use remote start, but I get the wrench symbol and my scanner reads does codes, truck runs like in limbo mode
Default 08-09-2018, 10:40 AM
Those are faults for the sensors the JB4 is attaching too. Email in some install photos and we can help you sort it.
Car: raptor
Default 08-09-2018, 10:42 AM
Gotcha what email
Default 08-09-2018, 10:45 AM
support@burgertuning.com is our general support email address.
Car: raptor
Default 08-09-2018, 06:41 PM
Done deal, email sent thx!
icecoldak's Avatar
icecoldak icecoldak is offline
Car: 2018 F-150 Limited
Default 08-09-2018, 09:40 PM
Please let us know what the issue was for future reference!!
Car: raptor
Default 08-09-2018, 09:44 PM
I will!
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 08-10-2018, 09:43 AM
Picked up the Jb4 for the @Lightning_blue_raptor yesterday. Install was simple and straight forward. Just funny standing on a ladder and core support to reach the sensors. Great seat of the pants feel for now on Map 1. Loving the new found power! Bluetooth app is super easy to use. Running JB4_F150_3 firmware with no issues.
Default 08-10-2018, 09:52 AM
Glad to hear! Be sure to try the valet map4 too, lol.
Car: raptor
Default 08-10-2018, 05:35 PM
I emailed support late yesterday with pictures of my install, and surprise, surprise, i had inverted the plugs...the rainbow ones go in the back, the brown ones go in the front...i feel like a moron, and i am very mechanically inclined go figure, so far no issue.
many thx to terry and the team!
I wonder how truck operated just fine that way, altough i really didnt use it much after the install either way, as last friday i got my gtr back from predator performance, and now has 719 hp at the wheels, in a very low ready mustang dyno. So naturally i have had to drive it everyday!
Default 08-10-2018, 06:17 PM
It actually works fine that way, but we found that having them backwards sometimes triggers a startup fault code. The MAP sensor turns on first I think causing it on a remote start.
icecoldak's Avatar
Default 08-10-2018, 10:48 PM
Sweet--so Im guessing it runs much better for you now? what Map you running
Car: raptor
Default 08-15-2018, 06:27 PM
Yes running perfect, no issues, on a raptor map 2 so far on 93 octane
Operator1331 Operator1331 is offline
Car: 2018 Ford Raptor
Default Map 2 logs - 08-20-2018, 08:49 AM
I'm new to the JB4 platform. Here are a couple Map 2 logs as well as csv files. Logs were generated this morning when temperature was 57 degrees. Fuel is 93 octane with Klotz octane boost. Added the amount called for to add 3 points so fuel should be roughly 96 octane.
Would be greatly appreciated if someone could check them out and let me know how the data looks? Any red flags?
Default 08-20-2018, 08:54 AM
Runs look good to me! Boost, timing, and AFR are all where they normally are on map2.
sym sym is offline
Car: Stinger
Default 08-20-2018, 09:52 AM
Got the ODB cable installed. My logs still have a lot of zeroes in them though - it looks like it isn't getting the VIN either.
Any suggestions? Power cycle the ECU?
Default 08-20-2018, 09:54 AM
Sometimes takes a few cycles for that to all kick on. Lock doors wait 10 min and see if that does it.
Default 08-20-2018, 10:25 AM
Thanks for the quick reply Terry!
Actually just got in the truck and got a wrench light powertrane warning. Hooked up forscan and it's code p0236 (Turbo Boost Sensor A Circuit Range/Performance). Wrench was gone on the next key cycle put code still active. Thoughts?
icecoldak's Avatar
Default 08-30-2018, 04:27 PM
Mighty quite in here
Terry----Any updates or progress for us F150 guys
Default 08-30-2018, 04:55 PM
Right now knee deep in trying to get it CARB approved. So no changes short term, but many happy customers, growing weekly. Once we have a CARB approved firmware setup for CA customers we'll start working on an alternative firmware for those outside CA to unlock some new features.
icecoldak's Avatar
Default 08-30-2018, 05:19 PM
Nice---unleash a little more power for us
Alex@abrhouston Alex@abrhouston is offline
Car: m3
Default 08-31-2018, 07:45 AM
how are we with the 04DB codes reappearing?
abrhouston.com
832-797-9114
Default 08-31-2018, 08:15 AM
The latest update resolved it for anyone we knew that had it. If you continue to have it then maybe some physical link like an intake or something extra throwing it over the edge.
jdm5596 jdm5596 is offline
Car: 335xi
Default 09-07-2018, 05:49 PM
Terry, why is jb4 not an option for 2015 f150 3.5L ecooboost? Would be cool to get one but it says either 2017+ or 2015+2.7L
Default 09-07-2018, 07:35 PM
We're working on it!! Some differences in the sensors and took awhile to find the right connectors for it.
