(#51)
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 01-31-2016, 09:13 PM
A small bit of lube does wonders for the O ring to TB you want the tight fit.. warm it up a little bit in some hot water.. swipe a little lube of choice, make sure it's aligned correctly and give her a push!
Default 02-01-2016, 12:02 PM
Did you learn this at an Asian Massage Parlor?
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 02-02-2016, 07:15 PM
Terry, this pipe is 2.5" correct?
2011 335is DCT, FBO
Default 02-02-2016, 08:42 PM
It's a 3" pipe and includes a 3"-2.5" elbow adapter.
bigdnno98's Avatar
Car: e92 335i
Default 02-02-2016, 08:56 PM
Awesome. Timeframe on the tial flange ones?
2011 335is DCT, FBO
Default 02-02-2016, 08:58 PM
A month? I'm having them hold the batch and grind out the TB opening so customers won't have any more headaches on that front.
bigdnno98's Avatar
Car: e92 335i
Default 02-02-2016, 09:15 PM
Ok thanks
2011 335is DCT, FBO
Enfiftyfore's Avatar
Enfiftyfore Enfiftyfore is offline
Car: 2009 135i
Default 02-03-2016, 05:48 AM
In4Tialflange
Default 02-03-2016, 11:38 AM
Found one of the problems. Our warehouse was supposed to swap out the crappy Chinese bung-cap (left) for the one we use with our BMS chargepipes (right). The right plug includes sealant and is a tighter fit so it can't screw all the way through.
If anyone bought the Phoenix Racing CP and needs the right caps just email me your address and we'll send a couple over.
Default 02-03-2016, 03:14 PM
I figured out why some of you are having fitment issues over the throttle body and some are not. Some have coating inside and some do not. The ones with no coating are a tight fit but with some lube go right on. The ones with the black coating will not go on at all. The black coating has to be sanded away to allow fitment. We'll take a grinder to what we have left in stock before shipping. If anyone received one with coating inside and doesn't want to sand the coating off the parts are fully returnable. Just send it back to the address on our site.
bigdnno98's Avatar
Car: e92 335i
Default 02-03-2016, 03:29 PM
Best customer service in the business
2011 335is DCT, FBO
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 02-10-2016, 08:20 AM
Yeah from what I can tell Terry's customer service is outstanding.. I'm definitely going to get in on that batch of Tial flanged CP's..
N54GOTU N54GOTU is offline
Car: 2008 335xi e90
Default 02-10-2016, 01:08 PM
Pretty cool, just picked a tial flange charge pipe for 117. Honestly it'd be better if you made greddy ***** because there are adaptors from greddy to everything iirc..
J. Dub J. Dub is offline
Default 02-11-2016, 09:26 AM
For those that don't want to wait for the tial style chargepipe. You can order these:
https://www.armmotorsports.com/N54-C...p/cp-t-335.htm
with that said, I support terry. And it will probably be worth the wait. But if you're impatient. See link above.
bigdnno98's Avatar
Car: e92 335i
Default 02-11-2016, 10:32 AM
I saw that one. Meth bungs are too close to the TB for my liking.
2011 335is DCT, FBO
Default 02-11-2016, 10:33 AM
But for those that don't run meth and don't plan to...
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 02-12-2016, 07:01 PM
I'm in for one with a Tial flange. Its time
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 02-13-2016, 02:03 AM
+1
Default 02-13-2016, 04:31 PM
Tial probably 3 months, HKS no plans.
How are we looking for March?
PhilTrill's Avatar
PhilTrill PhilTrill is offline
Car: 135', E46 M3, E36 M3, S13
Default 02-16-2016, 07:01 PM
Received my charge pipe today. The connection to the throttle body has been sanded but is extremely rough and the tmap sensor doesn't even fit, the hole is too small
Luckily I work at a machine shop and can fix these issues easily but you might want to look into it for your customers that aren't so fortunate.
Edit: just so we're clear i'm not hating, talking trash etc just constructive critism
'08 SGM 135i | '12 C63 AMG | '95 S14 | '93 S13 | '90 S13 | '89 S13 | '80 Spitfire
Default 02-16-2016, 09:06 PM
Not heard of any reports with the TMAP sensor, although that is easy to sand out. Probably also coating related. We used a rotary bit to clear out the coating on the inside of the throttle body flange. It's an ORING seal anyway so the finish is not relevant. Once you push it on you'll never see it again.
wnathan57 wnathan57 is offline
Car: 08 335i coupe
Default 02-22-2016, 12:58 PM
I received my charge pipe over the weekend and had the same problem with my tmap sensor and luckily I didn't have to sand the throttle body flange. A local machine shop fix the issue and now all is good.
Default 02-22-2016, 01:12 PM
Interesting. We'll start grinding the coating off the TMAP sensor hole too before shipment.
Car: 2009 135i
Default 02-22-2016, 01:17 PM
Terry, any update on Tial flange pipe?
Default 02-22-2016, 01:21 PM
We don't really do ETAs on stuff from China as they are notoriously unreliable on shipment dates. When we have them we'll post that we have them.
