(#2001)
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 02-07-2016, 01:26 PM
Are there any specific jb4 settings for the 335is when running a backend flash?
djlilmikeny1 djlilmikeny1 is offline
Car: 2011 BMW 335is
Default 02-07-2016, 04:44 PM
Steering wheel setting on 4/2, and put all AFR and duty bias to 0
FoShizzle's Avatar
Car: '11 335is DCT
Default 02-07-2016, 06:38 PM
Cool. Thanks. Already done.
S.W.G. S.W.G. is offline
Default 02-08-2016, 07:11 AM
Trying to flash my car with the same cable i used for my alpina tcu flash. When I connect, my Nexus tablet detects the USB, asks me if i want to use MHD, and I confirm. I select the map to update, and the second the program sends the signal, my light on the cable turns off, does a quick red flash for a second, and I get a 0v cannot connect to ECU error.
JB4 is set to map 0, car is on a charger, windows are up, doors are closed, radio is off, other electrical components are off.
Is this a bad cable or is there a versioning thing going on? I'm on the latest release of JB4, MHD, and android OS on my tablet.
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 02-08-2016, 07:25 AM
kill all apps on the Android device. remove cable from obd2 port and phone. make sure phone is unlocked. plug cable into the car. Red light should illuminate. turn on ignition. then plug cable into Android device and wait for MHD to autostart. should autostart in under 5 seconds if all apps were killed.
Then proceed to flash. DO NOT jiggle the cable. i have noticed some of those cables have connection issues when bumped or moved a bit while plugged in.
try that and report back.
EDIT: if the android device does not autostart when the cable is plugged in. completely reboot the phone and try again. if it still doesn't autostart. your OTG cable may be faulty.
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 02-08-2016, 07:32 AM
Not sure but I guess keeping driver door open required to keep the ECU from going into sleep mode
Default 02-08-2016, 07:34 AM
ecu wont sleep with ignition on to my understanding. i never have door open when flashing or anything.
Jboyorak Jboyorak is offline
Car: 335xi
Default 02-08-2016, 07:41 AM
It can shut off if you open or close door with the key on.
Default 02-08-2016, 07:48 AM
yes, i was thinking he meant by just sitting there. but you are correct. i always flash with the door closed. i don't even touch the windows or door locks, lol
Timmay77 Timmay77 is offline
Car: 2008 535xiT
Default 02-08-2016, 08:06 AM
If I am just a FBO car that doesn't run E85, is it worth updating?
2014 328i xDrive Msport
Default 02-08-2016, 08:28 AM
updating what?
Car: 2008 535xiT
Default 02-08-2016, 08:34 AM
updating what?
I haven't updated the MHD BEF since 12/13/15. Is it worth updating to the latest release?
Colorado335 Colorado335 is offline
Car: 2010 335Xdrive
Default 02-08-2016, 12:20 PM
Just wanted to post my graph see what you guys think and what I can approve on. This is only a second gear pull.
2010 335 X Drive
Bandimere Speed Way 5,800' / Track Time:TBD
VRSF DP, BMS-CP, Tial Sport Blow Off Valve, VRSF 7" FMIC, RB Inlets,, Koni struts w/Tein Springs, Spec Stage 2 Clutch Spec Flywheel, JB-4, MHD Backend Flash
Junkyarddogg Junkyarddogg is offline
Car: 2011 E92 335is
Default 02-08-2016, 01:08 PM
Newbie question..
How do I safely run a 93 map if only 91 is available? Fill up with a bit of E85? How do I know how much E85 is in the tank?
matthewo matthewo is offline
Default 02-08-2016, 09:10 PM
Been having 7f2811 error on initial flash 2-3% and car becomes unstartable. Left me stranded at gas stations for 20 minutes or so until it finally works.
Had to retry flash 5-8 times before it worked. Any idea?
It was a jb4 back end map change
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 02-08-2016, 09:12 PM
^^I'm having issues also. I have a known good CAN cable and the tablet seems to be working fine. I think it's my OTG adapter.
2011 335is DCT, FBO
bigdnno98's Avatar
Car: e92 335i
Default 02-08-2016, 09:16 PM
My write failed 2 seconds in Saturday night. Car wouldn't start and had a ton of errors. I tried the flash again and it worked. I set the tablet on the brake pedal, OTG up, and tried not to move anything. It finally flashed. Bi did get a DTC/DSC malfunction on the way to work this morning though
2011 335is DCT, FBO
zeeth2800 zeeth2800 is offline
Default 02-09-2016, 08:52 PM
Couple of questions for the MHD developers..
Are you guys close to supporting a 3 port solenoid to control boost on ST cars?
Is any type of launch control/2step in the works?
I saw the post about the shift bog on 6-speed cars. Are those settings something I could ask my tuner to incorporate into my map as a revision?
Really excited about going to a factory DME/3 port controlled boost vs my current EBC setup. Leaps and bounds have been made in this platform recently. Excellent job.
2008 135i SGM 6-Speed l AD Engineering ST 6262BB l MHD Tuned l MAXBoost/N20 Map l GFB electronic boost controller l Spec 2+ l Walbro 450 LPFP l VRSF 7" FMIC l VRSF CP l Tial BOV l N55 Midpipe l Custom Straight pipe catback l BMS Catch Can l RB pcv l
Enfiftyfore's Avatar
Enfiftyfore Enfiftyfore is offline
Car: 2009 135i
Default E85 cold weather update - 02-10-2016, 04:54 AM
I updated my E85 backend this morning before work (30 out). The update went fine but now the car drives like it's stock. I put it in map 0 before the flash and then back to map 7 afterwards. The gauges aren't hijacked either. What happened?
Edit: The car is driving like the Jb4 is completely off and there is no backend flash. I went out and redid the flash but I can't drive it until this afternoon.
Turned ignition on ➡Plug in MHD ➡Found new MHD file ➡Set JB4 to Map 0 ➡Start amd finish write and completed without errors ➡Turn car off and remove key ➡Unplug MHD ➡Start Car Set to Map 7
These are the steps that I used, hopefully it work this afternoon. @MHD what happened?
Default 02-10-2016, 06:01 AM
Set jb4 to 4/2?
Car: 2009 135i
Default 02-10-2016, 06:02 AM
Originally Posted by Ocean
Set jb4 to 4/2?
It didn't move from 4/2, but yes I did check.
It shouldn't matter anyways because it isn't even driving like the JB4 is on at all. Like I said, no hijacking or anything.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 02-10-2016, 09:39 AM
I cannot something wrong. Make sure ignition is ON. If the issue persist drop me an email.
Originally Posted by Junkyarddogg
Newbie question..
Just add 20% of e85.
I have disabled the section that was causing this error in the latest 1.30 build.
Thanks. Jake Yamona / MOTIV is working on this.
Looks like a JB4 issue, not flash related. Update?
omarmarji's Avatar
omarmarji omarmarji is offline
Car: n54 335
Default 02-10-2016, 10:51 AM
the settings in the jb4 need to be adjusted
Duty BIAS all to 0
AFR all to 0
meth trigger at 0
n20(if not using it) 0
then set the jb4 to speedo 4 rpm 2
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
CURRENT: E82 135i (under construction)
Visit my website VaderSolution.com !
Car: 2009 135i
Default 02-10-2016, 11:25 AM
Duty BIAS all to 0
AFR all to 0
meth trigger at 0
Why would that matter if I'm running Map 7?
Also, when I was running the E85 backend before today, there was no issues whatsoever.
Car: 2009 135i
Default 02-10-2016, 01:08 PM
I am not sure what happened this morning but after reflashing again, it's driving normal jow. JB4 and Backend are both working.
