romnation romnation is offline
Car: 2009 135i
Default Does the tune need to be removed to do an ECU firmware update? - 08-12-2019, 01:55 PM
I currently run an MHD back end flash + JB4. Does some or all of this need to removed before updating the factory ECU firmware?
Default 08-12-2019, 06:15 PM
Not sure I follow- are you referring to your stock file?
If yes, JB4 would need to be in map 0
Car: 2009 135i
Default 08-12-2019, 06:22 PM
Correct, the stock file for the DME. I currently run the MHD backend flash for jb4 (The e85 flash) Will these need to be removed as well?
After the car's firmware upgrade will I need to reapply the mhd back end flash?
Default 08-13-2019, 09:53 PM
After car is flashed - yes you’ll want to reflash the bef
