dizzer23 dizzer23 is offline
Car: 2011 335is e93
Default Log Review - stg 2+ lpfp - 08-07-2019, 02:22 PM
Hey all,
Just had a fuel-it bucketless stg 2+ lpfp installed and did a few dyno pulls after. log below.
fwiw, car made 408 whp // 423 wtq on this pull
any feedback is appreciated!
mod list:
vrsf ********* **
vrsf 7.5 FMIC
vrsf CP
BMS DCI
fuel it stage 2+ lpfp
JB4 (map 5)
pump BEF
~e25 mix
Default 08-07-2019, 10:34 PM
Fuel wise looks ok- trims getting up there thought.
Map 5 imo isn’t really a great Dyno map- can be a little inconsistent
Car: 2011 335is e93
Default 08-12-2019, 02:06 PM
Hey Dave,
Thanks for the response. Any suggestions to help get those trims in check?
I agree on Map 5 - 3 pulls, 3 different HP numbers within ~25 hp of eachother. TQ stayed within 3 points of eachother though. Map 2 came in at 383 WHP & 450 WTQ (final run, a bit heat soaked).
Another note..
Got some weird codes & half engine lights yesterday, and gas gauge stopped working correctly. Assume this is related to the STG2+ install. I had 1/4 tank of gas when I got the CEL - I ended up putting 13.5 gallons of 93 in and the gauge didn't budge from 1/4.
2FE5
2FE7
29DC - Cylinder injection switch-off.
Unfortunately, no logs as these all happened at low throttle.
Any insights? I'm taking it back to the shop tomorrow and any guidance you could give on where to begin troubleshooting would be beneficial.
Default 08-12-2019, 06:13 PM
Double check to make sure nothing is blocking the float assembly
