gklhso's Avatar
gklhso gklhso is offline
Car: F30 335i
Default 08-11-2019, 07:23 AM
Hello Dave, how r u doing ? I am nearly done with testing and tweeking my setup with port injection, e70 mix and bm10 nozzle on 70/30 meth water mix, the only stupid thing I did was settings for map 6, I am having trouble with traction so I made a custom map 6 with boost by rpm but I calculates it wrong so third gear was ok then 4th gear I lost boost in midrange and then went back to the top, by the way I am now hitting 28 PSI and the ambient temp is 27c and humidity is 70-80 % I wanted to try the desensed knock sensors but I am not so sure :D
gklhso's Avatar
Car: F30 335i
Default 08-11-2019, 07:24 AM
Ohhh I forgot, will try 50% meth fuel mix today, fingures crossed, I hope it all goes good
gklhso's Avatar
Car: F30 335i
Default 08-11-2019, 07:42 AM
the question I have is if it is normal that timing drops to zero between shifts? And is it normal that my max timing is 6 to 7 ?
gklhso's Avatar
Car: F30 335i
Default 08-12-2019, 05:11 AM
I finally tried the 50 50 methanol petrol mix, and surprisingly, the results are very promising ! Here are some logs, ps temp is 27 degree and humidity is 60%
I NEED your feedback!
gklhso's Avatar
Car: F30 335i
Default 08-14-2019, 09:54 PM
Hello?!
Default 08-15-2019, 11:14 AM
Looked at the last 2 logs- this does look improved.
Trims could use a little adjusting (trying to pull fuel)- & some corrections especially on 4/5
That being said this does look to be moving in right direction!
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
gklhso's Avatar
Car: F30 335i
Default 08-15-2019, 09:56 PM
Today I tried again but with ethanol, e70 mix but the wheather was very bad, temp was 27 degree and humidity was 80% !!! Timing was all over the place and my 100-200 times on the same road I use got worse (6.5 compared to 5.9 the other day but temps were around 23 degree and humidity was better)
