mattgu40 mattgu40 is offline
Default Dyno tomorrow Log Review - 08-12-2019, 11:56 AM
Hi there.
going on the dyno tomorrow morning and would like some fine tuning and advices before. will post after
JB4+ Custom BEF
Pump+ meth port injection 550cc
Fbo
VTT GC 1 with inlet and outlet.
2009 awd
final boost leak test tonight and ready to go
will post logs and Dyno sheet
Default 08-12-2019, 01:15 PM
I don’t like to step on custom “tuners” toes- but I’d ask whoever is dialing your car in, why your trims are pegged at 0 (pulling fuel)
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-12-2019, 03:00 PM
Any way to fix the problems without changing the custum tune as he is away
Default 08-12-2019, 06:15 PM
I don’t know what they’ve done to alter the map.
If you were using our OTS maps- it’d be easier
e92 AT 335xi 2.0
Doc Race Kit 6062
codesx codesx is offline
Default 08-13-2019, 09:59 AM
Did you do the dyno run?
If so, post the logs.
First, read my response with salt handy...
With my car (not port injection, just CP) when my Trims bottom out like that, I get more timing pulls.
You do not get this, or anything during shifting gears.
There's no chance he desensitized your knock sensors, is there?
The Ign timing looks like a single gear, semi-optimal (not too advanced early on).
Almost like it's hard coded, rather than dynamic, if that is possible. (desensitized?)
The little I know says we'd need to be privy to all the tweaks before any suggestions could be made.
Nothing appears wrong though. Quite the opposite.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
2018 - A/T Replaced | Plugs | Ign Coils | Walnut Blasting
2019 - Index 12 Injectors | VCG | OFHG & O-rings | Alternator w/ Clutch Pulley | Water Pump & TStat
Default 08-13-2019, 10:51 AM
Got refused the dyno as he seen the xdrive tag . Got xdelete but he said if something goes wrong. Suggested tu pull front driveshaft in parking lot he still declined.
Hope the knock tables are untouched.
Running 94 aki E10 with pure meth hope its why i do not get any knock.
Thanks for input will see if i can find another dyno this week
Default 08-13-2019, 09:56 PM
Whose tuning the car?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-15-2019, 09:33 PM
I’d talk with your tuner about any questions - tbh we aren’t sure what custom tuners do / what they after in their BEFs
e92 AT 335xi 2.0
Doc Race Kit 6062
