Souprah Souprah is offline
Car: 335xi 6mt
Default Bank 1 leaning out (Map 4 kickback) and cannot figure out why - 07-23-2019, 02:45 AM
https://***********/u/souprah/bank-1...log=0&data=1-4
Iím kinda stuck here with a Bank 1 lean condition.
Car drives around normally fine, but as soon as it sees boost above stock bank one just goes super lean.
1. Thought it would be injectors, so I replaced bank 1 injectors with good injectors and same thing. I was running open ******** while this happened so I figured it could have been because of that and I did start getting a ďLambda bank 2 trimm controlĒ code.
2. Put exhaust back on and replaced both Primary O2ís and still the same issue (no more code though).
3. I then swapped bank 1 and 2 injectors to see if it would atleast move banks and no change in logs. Bank 1 still leans out.
4. Then I swapped coils from bank 1 and bank 2 and same thing (All Delphi). Gonna check plugs out tomorrow but it wouldnít make sense as to why plugs would cause a lean condition. They are NGKís with about 3,000 miles on them.
Didnít think it would be this deep of an issue. Only thing I can think of to do next is check out MOSFETS and maybe swap out the secondary o2ís?
Any help would be appreciated! Log posted above
Mods:
07 XI 6spd
FBO
VRSF 7ĒHD
Walbro 450 running e60
JB4 with e85 BEF
VRSF DPís
BMS DCI
Stock turbos
Default 07-23-2019, 12:20 PM
Hey can you just upload the CSV file? We don't use 3rd party host sites for log viewing.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 335xi 6mt
Default 07-24-2019, 10:15 AM
Oops sorry! Yeah forsure I will do that once I get to my laptop. Thanks!
Update: So far I reflashed the e85 backend flash and I am running straight 93. Bank 1 seems fine right now and the car isnít leaning out in bank 1 under WOT. Gonna try to add some e85 and see if anything changes!
Also going to check my mosfets just to be safe but hopefully car will be fine now. Doubtful since I really didnít fix anything but we will see!
Default 07-24-2019, 09:55 PM
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 335xi 6mt
Default 07-29-2019, 01:09 PM
*2 Years Later*
Here is the CSV file! Car was running great for a few days and then I got one random map 4 kickback. Still have not checked MOSFETS but will be doing that tonight!
Let me know what you think thanks again
Default 07-29-2019, 10:28 PM
Did you add e85?
Afr still looks off, and you get some bank to bank variations
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 335xi 6mt
Default 08-12-2019, 11:16 AM
I finally added some e85 and have been driving the car around. No more problems really. Still makes me wonder why my car was doing it before. Going to go ahead and pull through with the Trebila tune hoping the car stays healthy. Here are a few more recent logs I have of the car!
File Type: csv 2019-08-07 20_47_19 (diag bank 1)_Map-5 34 pull 30 to 120mph.csv (20.4 KB, 13 views)
Default 08-12-2019, 01:17 PM
Enable 6cyl timing
And over next few days monitor both banks afr
e92 AT 335xi 2.0
Doc Race Kit 6062
