Xm4tr1x Xm4tr1x is offline
Car: 08 335i
Default Help understanding my power limit - 08-09-2019, 06:33 PM
Hi Guys, I'm hoping someone can help me understand why my tuner stopped where he did, he said on the 3rd revision "this will wrap it up" and with no reply to my further questions, so i ask the N54 community whats the go here, I've just done a full major on engine and tranny, replaced turbos and all leaking gaskets, Current Modifications: DCI 2" inlets TD04 17T turbos, Outlets, 7" HD FMIC, CP, Turbosmart Diverters, N20 TMAP, Upgraded PCV, OCC, Dumps, BMS oil cooler mod, xhp stage 3, index 12 injectors running 98ron
here are my 3 logs from from each revision
my questions are:
why is the last rev lower in target psi?
why did he stop am i at the limit of something?
can i make more power on 98?
see attached CSV files from each rev
any info will be greatly appreciated, thanks again
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 08-09-2019, 07:12 PM
You need to upload cvs files for anyone to look at your logs.
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5 RACE FMIC
VRSF DPs - VRSF INLETS - VRSF OUTLETS
NGK 97506 @.022 - STAGE 2 LPFP - H&R SPRINGS
19 666m WHEELS - HANKOOK VENTUS V12 EVO 2s
Car: 08 335i
Default 08-09-2019, 07:44 PM
Thank you,I have edited OP
Default 08-09-2019, 08:37 PM
Can only help you with JB4 logs on this forum, sorry!
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 08-11-2019, 06:26 PM
Im used to JB4 logs so didnt spend much time looking but my guess based on mods is fuel volume, you probably need CPI or PI. Also would get bigger/denser IC.
