Limpmode's Avatar
Limpmode Limpmode is offline
Car: 2007 E90 335i
Default N20 TMAP settings - 08-16-2017, 09:54 PM
Besides setting TMAP to 1, is FF duty bias required to be set to 20?
I'm using the iOS 3rd party interface, and didn't see that setting on the user adjustment settings page.
Any other settings change info would be great. This is the first time I'm running the 3.5 bar TMAP.
I read through the threads from 2013, but I'd imagine some of that info is outdated by now.
07 335i; JB4, Anti Lag, MHD BEF, BMS DCI, Phoenix CP, Tial BOV, MAP OC, BMS OCC, 1320 Down *****, MMP Inlets, RB Ext PCV, Mishimoto OCC, BMS Meth, N20 TMAP, VTT stock+billet comp wheels, Blk124 Wheels (5series take offs staggered), 275/35/18
TheDoctor's Avatar
TheDoctor TheDoctor is offline
Car: BMW 335i
Default 08-16-2017, 10:26 PM
As for the TMAP changing the value from 0 to 1 that is correct, but as for the FF duty bias you don't need to change it unless you want to match the boost curve on the boost target, so you better know how to use it.
335i M//, 07",IC, CP, BOV, LPFP stage 3, Meth kit, MHD ST,PI,PTE 6466, 32psi ~ 750whp
Limpmode's Avatar
Car: 2007 E90 335i
Default 08-17-2017, 02:16 PM
^Thanks for the info! For the time being I won't mess with the ff duty bias.
Just for my own sake of knowing, what does the following statement mean?
"and also realize your FF/duty bias values will be approx 20% lower than they were with the 2.5bar factory sensor. An easy way to offset this is by adding 20 to each duty bias value across the board to keep FF within a usable range."
Is this just outdated info?
sti917's Avatar
sti917 sti917 is offline
Car: 2011 bmw 335i e90 M tech AT
Send a message via AIM to sti917
Default 11-16-2018, 02:44 AM
Is this outdated info?????
2011 335i sedan Auto xhp flash 11.9 @118 mph (uphill)
jb4 Bef, pure stage 1, meth, boost activated exhaust cutout on ********, BMS spacers, BMS air intake, BMS cowl filters
Dannyzack99 Dannyzack99 is offline
Car: 09 335xi FBO
Default 05-20-2019, 08:14 PM
Iím curious as well, is it still necessary to adjust duty bias??
