miksebik miksebik is offline
Default Boost reaching target fast but under target between 3000 and 4000rpm - 03-15-2019, 01:19 AM
I had my car in a service. The front turbo was adjusted as the flap did not close properly. Now it seems OK, the boost builds very fast. But then I found that at map2, I stay under (1-2PSI) under target, between 3000 and 4000rpm.
I guess duty bias tunning will solve this?
flash: PUMP flash
map: 2
btw I know the log is not clean as I had problems with traction etc.. This is about the slight underboost in 3000-4000rpm range.
Thanks,
Mike
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
Default 03-15-2019, 01:41 AM
I noticed that ecu_psi differs from boost by 2PSI.. while the boost is 17, the ecu_psi is still around 15. That might be the clue?
Default 03-15-2019, 10:52 PM
Raise your DB by 5 from 3k To 4K
Take 2-3 adaptation pulls & relog
Default 03-16-2019, 03:30 AM
Dave, I set FUD to 64 and decided to adjust duty bias in all rpms. Does it make sense? I think I am OK in the range up to 5000. Now I am under target above 5000rpm, I have to increase the duty bias there too.
Is it normal that I had to set DB=80 in certain rpms?
Default 03-17-2019, 07:57 AM
Where did you come up with those duty bias #s? Hah
You can manipulate the car however you wish. Generally I like to keep my duty bias adjustments small & close to one another to avoid a jagged boost curve.
Remember stock turbos arenít going to hold a ton of boost at redline and if they do you are working them hard & out of efficiency.
Default 03-17-2019, 02:27 PM
Well, I am raising the duty bias on my own in order to reach the target. OK, I will try to put them closer together but honestly, the car does not feel weird. Shrug.
With numbers around 70-80 the boost will likely reach the target. My turbos are not OEM, it is Hexon RR500 with slightly bigger wheels than OEM. It is weird that earlier, there was no need to tune the duty bias..
Default 03-17-2019, 10:52 PM
With numbers around 70-80 the boost will likely reach the target. My turbos are not OEM, it is Hexon RR500 with slightly bigger wheels than OEM. It is weird that earlier, there was no need to tune the duty bias...
As stated prior- you can alter your DB settings however you wish, your car, you can tune it, raise the boost, lower the boost, go into the flash and alter tables- whatever you desire- we WONT stop you. What we will do however is give insight & suggestions based on seeing countless different setup over the years.
It seems like you got it under control, so I will bow out, best of luck & be safe
Default 12-08-2019, 01:57 AM
Hi, to sum it up.. You know what was the cause of this weird problem?
Cracked ER aluminium chargepipe! With low boost, it behave well, but with the pressure building, the crack got wider and let pressure off.
Default 12-08-2019, 05:21 AM
Where was it cracked? Donít hear that too often, glad u found the issue!
Default 12-08-2019, 06:26 AM
It was right at the bayonet, or how you call it in English...
I bought this branded chargepipe, the most expensive on market at its time.. to prevent such problems but here you go. Nothing is perfect.
