tumminellon tumminellon is offline
Car: 335i e90
Default before meth log - 02-23-2019, 12:25 PM
trying to figure out if everything is good before I turn the meth on car is intercooler, ******* down ***** deleted second cats, dual nozzle #5 meth kit, and dual bms airfilter kit, I had to adjust the rear w/g arm to get rid of rattle so I'm sure it needs turbos.....
both pulls were made on map2
car is mhd bef race
first pull had traction control on my bad
Default 02-23-2019, 10:44 PM
car is mhd bef race
You need to enable 6 cyl logging.
Your LPFP is crashing - i wouldnít turn the car up until you address that. I donít see an LPFP on your mod list
Car: 335i e90
Default 02-24-2019, 08:36 AM
Where should I start checking or should I just upgrade? What do you recommended
Car: 335i e90
Default 02-24-2019, 09:22 AM
Also going to be putting pures new cast manifold stg2 turbos on it so I want enough fuel for that... and of course some corn later on
Default 02-24-2019, 10:15 AM
If looking to blend ethanol- our stage 2 bucketless is a great place to start & will greatly help with your current issue:
N54 BMW Fuel Pump Upgrades & Tool - BurgerTuning.com
Car: 335i e90
Default 02-24-2019, 01:18 PM
Will this support the pure stage 2 turbos or is going a higher step better for added port injection later?
Default 02-24-2019, 05:15 PM
It will support around the 600 whp range.
Itís modular, and an additional pump can be added easily
Car: 335i e90
Default 02-24-2019, 05:41 PM
Is the bucketed version better?
Default 02-24-2019, 09:43 PM
Depends how you describe ďbetter.Ē
The bucketless option will flow about 27% more than the Bucketed w. The same pump.
Bucketless is modular, easier to add an additional pump if you ever needed more fuel.
If you want a bucket- id look into this instead: BMW E-Series FI-650HP LPFP Upgrade - FUEL-IT!
Car: 335i e90
Default new pump - 03-09-2019, 12:02 AM
here is a 3rd gear pull with new fuel pump installed how does it look? Map2 jb4mhd race bef. 93.
Default 03-09-2019, 08:31 AM
Boost looks good
Fuel pressure (high / low) look solid
Your getting a bit of timing corrections across multiple cylinders- probably from octane / the 93.
Which LPFP did you go with ?
Car: 335i e90
Default 03-09-2019, 09:13 AM
Walbro 450 bucketed... so what do I do next when do I turn on meth
Default 03-09-2019, 09:36 AM
You can implement the methanol whenever.
Just make sure you adjust your user settings appropriately / log
Car: 335i e90
Default 03-09-2019, 11:21 AM
When you say adjust the user settings accordingly you mean the boost additive should I just input the default settings and work my way up Iím also spraying 100 % methanol
Default 03-09-2019, 10:35 PM
Correct
Car: 335i e90
Default 03-11-2019, 06:02 AM
map 3 short pull seemed to be low on boost and meth flow.... where should I start? all new meth kit devils own pump, lines, solenoid and 2 new #5 nozzles. being controlled by a fsb.
Default 03-12-2019, 08:46 AM
Typically a decaying signal means there is some physical issue like air in the lines. Photo of the pump/tank location and setup?
Default 03-12-2019, 09:53 AM
Saw photos of WMI kit, problem is pump location placement. It has to be in back with tank.
Car: 335i e90
Default 03-14-2019, 07:01 AM
map 3 full pull relocated pump to trunk under tank additive 40 100%methanol can I go up more? and should I have pwm on or off if on no meth flow occurs
Car: 335i e90
Default 03-15-2019, 09:39 PM
Helppppp
