steelheadtom steelheadtom is offline
Car: 2008 BMW 335xi sedan n54
Default 2008 335xi sedan data log and code 2D2E - 02-19-2019, 12:38 PM
2008 335xi sedan
ZF6
n54
mods:
XHP stage 3 trans flash
BMW performance exhaust & resonator delete
BMS DCI
BMS catch can
VRSF charge pipe with TIAL BOV
Vader Solutions BOV adapter
JB4 Map 1
Ive been getting 2D2E codes ever since I installed the jb4 back in November. I figured it was the meth bungs that I had not properly sealed up with pipe tape but after sealing those and checking to make sure clamps were not leaking on intercooler side of charge pipe (replaced the T clamps with Pipe clamps, definitely a better clamp) the jerkiness under light load in higher rpms got way better but is still there from time to time. I wanted some input on what else could be causing this code? I read in other threads that it could possibly be a tuning error under menus 10 or 12 which I did screw around with a bit but ultimately could not figure out. I returned the menus to their stock values that they where at when I first installed the jb4 after screwing around with them a few weeks ago ( menu 10: 3000, menu 12: 2700). The SOS light will also come on from time to time when the code is triggered but not every time it is triggered. Id imagine that has something to do with having the auto clear function enabled. Anyway, if I could get some input on the data log I did an hour ago it would be much appreciated. Im relatively new to all of this tuning and forum use so any advice would help.
2019-02-19 13_42_07 Map-1.csv
Default 02-19-2019, 02:08 PM
Originally Posted by steelheadtom
2008 335xi sedan
ZF6
n54
mods:
BMS DCI
BMS catch can
JB4 Map 1
Attachment 83829
2D2E- to my knowledge is due to having menu 10 or 12 set too high.
Try lowering menu 10 to around 2k
Default 02-19-2019, 02:12 PM
I'll give that a try and get back soon. Thanks!
Default 02-19-2019, 10:21 PM
Sounds good!
Default 02-20-2019, 10:46 AM
Lowering that menu 10 value down to 2k really helped out a ton. much smoother. Thanks!
Default 02-20-2019, 09:25 PM
Happy to assist
hawaiidragracer hawaiidragracer is offline
Car: 2010 BMW 135i N54
Default how can I change the map 10 settings - 03-12-2019, 09:14 AM
I have the bluetooth connect kit and android. how can I change the map 10 setting to try to eliminate the 2D2E code?
Default 03-12-2019, 09:47 PM
U can use the app or the wheel controls
Default how can I change the map 10 settings - 03-13-2019, 08:36 AM
I don't see where to change it in the AP. I go to settings, then under the JB4 Settings tab, User Adjustment. But I don't see what to change in there. Where should I be looking?
