Bours Bours is offline
Car: 335i x-drive n55 2011
Default benefits of going over 21 psi ? - 04-21-2017, 05:42 AM
hey guys im currently n55 FBO minus intercooler on meth 95/5 20psi and just ran 12.360 ET @ 113mph as some of you may know.
I just bought a N20 sensor and adapter to go over 20 psi
Id like to know if there is potential of going even faster and making bigger numbers by running like 23 psi and adding E off course to get better timing
OR
past 20 psi on stocker there is nothing else to gain ? i know im pwm maxed out from 4700 rpm to 7000 rpm right now but will i get more torque or hp in the mid range or down low by doing so ? I wanna get my 12 flat before going PS2 let me know in the comments section below !
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
JB4OFF JB4OFF is offline
Car: 340i
Default 04-21-2017, 06:36 AM
You would have to evaluate the log and see for yourself. I would probably switch to 100% meth content and run some e30, if you plan on doing that. After a certain point, you'll lose efficiency. I mean you can only push so much air out of a straw. Your basically at 12 flat. Just need a better 60ft. I wouldnt split hairs over .3 milliseconds...
Default 04-21-2017, 07:36 AM
yea good info bud. In your opinion, past 21 psi am i loosing effiency ? e30 and 100 meth thats exactly what i was planning im guessing ill get more torque down low but nothing mid range and up (*maxed out and hp maxed out )
yea i need a 1.6 60ft ill practice on that
if this doesnt work at least ill have n20 sensor for my incoming ps2
feel free to give advice
Default 04-21-2017, 08:18 AM
Originally Posted by cnm135i
Stock turbo - right? If so there isn't any more hp in it, but you might get 30nm more for 200rpm
yup stocker
30nm lolll thats nothing and where in the power band these 200 rpm ?
Car: 340i
Default 04-21-2017, 08:46 AM
Any time brother. Again, idk you would have to look at you logs and see. If you have a vbox that will also be helpful. And, most importantly You need to judge how it feels from driving it since you know your car best.
I just don't want you to blow a turbo just for a time slip.
Default 04-21-2017, 09:16 AM
well said yea a vbox is in my plans for sure ( such useful data )
yea but to be honest i kinda want to wear it fast i dont really care cause i will upgrade to ps2 anyway . I just hope it doesnt bring down other important components around the turbo !
Car: 340i
Default 04-21-2017, 09:27 AM
If the cars maintenance is all up to date and is healthy. Then fiddle with it. Up it until you get a negative reaction. Take it 1/2 psi at a time lol
Jmwilson125 Jmwilson125 is offline
Car: M235i
Default 04-21-2017, 09:41 AM
OR
What are your jb4 methanol settings if you don't mind me asking. I am in a similar boat right now. Fbo e30 meth50/50
So far I have only hit low 18 psi on additive 75. However, I don't want to wear my turbo out, I decided not to go PS2.
2016 M235i EWG N55 - Empty exhaust - Charge Pipe - Intake - FMIC - WMI kit dual cm5+cm7 - JB4 FF and EWG Wires.
Default 04-21-2017, 09:55 AM
i put additive 50
meth safety 0
meth flow 7.5 psi
meth trigger 0
its weird that u only hit 18 if additive is at 75 might have a boost leak
may i ask why no ps2 ?
Car: 340i
Default 04-21-2017, 10:51 AM
You need more meth. You might not be hitting targets because of an octane issue. Are still stock flash?
Car: M235i
Default 04-21-2017, 11:17 AM
i put additive 50
meth safety 0
meth flow 7.5 psi
meth trigger 0
Looking at the chart Terry posted it shows 75 additive targets 19.8 if ign avg is 1.5 or below. My ign avg has been between 2.5 and 3. I suspect it will be a little lower with a tad more e85.
No PS2 mostly because of cost. I'm young and bought an expensive car and modded under warranty. I am playing with fire as is, I don't think I want to play with the inferno just yet.
It is not out of the question but as of right now I am pretty happy with performance. Just trying to maximize the benefit of the wmi setup that I just added
Car: M235i
Default 04-21-2017, 11:40 AM
Yes no flash tune, just jb4. I have not found a place to purchase meth yet, I have just been trying the boost juice so far. I have a couple bottles of heet, but I am hesitant to use that.
Default 04-21-2017, 12:13 PM
Nothing much to be gained except a little torque down low...that isn't going to help you much though. On the PS2, definitely!
Car: 340i
Default 04-21-2017, 12:20 PM
Contact vp fuels and they should have dealer near by. Heet works but expensive if your sole purpose is meth content. I've used it before. You can also try denatured alcohol
Car: M235i
Default 04-21-2017, 12:54 PM
Ah I did look up VP fuels too. Shipping cost $120 for harzard fee. If there is one local I could pick up. I'll have to call. I'm in the Boston area.
Car: 340i
Default 04-21-2017, 01:57 PM
Race shops are usually dealers for them. Give them a call and I'm sure they can get it without paying the hazament fee. Give denatured alky a shot as well. Can easily be purchased at a local hardware store. It's mixture of ethanol/methanol 45/55 usually or 50/50 is the mix in those. And lower your additive. You may be over boosting and car is trying too correct it by lowering targets, closing throttle, etc. believe me a higher number doesn't always mean more power. I prefer just straight methanol, straight denatured alcohol or straight e98. Believe me water doesn't help **** with IAT's in the charge pipe. Let the FMIC keep everything nice and cool. Timing should ramp up nicely with more.
Default 04-21-2017, 02:15 PM
stocker was a nice story on to the next one i guess ! thx steve ! ( ps2 )
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-21-2017, 04:02 PM
They are tenths of a second not milliseconds.
Two things that will come into play. If he is running JB4 only, as he states below, then he will not be on the higher psi targets that you see with the MHD flash, therefor he needs a higher additive to target higher boost. The target builds off map 1 boost level. I saw the other was also mentioned. You will only see the full additive boost value if your AVG IGN is lower than 1.5.
What was odd about this is in your logs boost did not reduce when your AVG IGN went above 1.5
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
VRSF Chargepipe | BMS Intake | JB4 ISO | N20 TMAP | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | BMS Methanol Injection |
Car: M235i
Default 04-21-2017, 06:04 PM
Target should be 19.8 I think I hit 18.2 with an avg ign of 2.3ish
Default 04-22-2017, 04:46 AM
Flat 20psi vs flat 16psi. Just more torque - same hp up top.
yea up top same hp but if you look at midrange there i clearly quite a bit more hp and more torque
i know after 5.5k rpm it same but in the midrange there might be more torque a few whp to squeeze out imo ill log it and report once i receive my n20 sensor
i dont think too much people tried 23-24 psi on stock n55 turbo e series
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 04-22-2017, 05:26 PM
Not really part of the original topic, but if you're in the Boston area, I buy my methanol from
Karl's East Coast Speed
3145 Post Road
Warwick RI 02886
The last time I bought it, it was $7/gal. I bought 2 gallons, and mixed in 2 gallons of distilled H2O and added some drops of red dye. If you want more info, shoot me a PM. I don't track my car and I'm not on boost regularly so I haven't used up the 4 gal yet.
Car: M235i
Default 04-23-2017, 06:48 AM
3145 Post Road
Warwick RI 02886
Sounds good. I'll have to check them out. And to loop this back to 21+ psi topic. Does anyone have fueling suggestions to hit that Target based on my mods. I have ethanol available and wmi kit. I have been logging and playing with it, but haven't found the sweet spot yet. E30 and 60/40 meth. I'll pay the logs in the other section.
Default 04-23-2017, 08:16 AM
Anybody here been running 23-24 psi on stocker ?
keyap keyap is offline
Car: N55 135i
Default 04-23-2017, 09:41 AM
Irrespective of other mods, that's not possible with an E Series N55 OEM turbo.
Pre PS2, even if I targeted 23, the best I could get to would be 20, maybe 21 if I was lucky, in the low to mid rpms, tapering to low teens in the upper rpms. When achieving this, PWM would be >90 indicating the turbo was pretty much maxed out
[B]
Suckadeez's Avatar
Suckadeez Suckadeez is offline
Car: 2011 335xi
Most boost Ive seen is 20.8psi with e50 and meth 50/50 with 75 add going off at 10 psi. But that's stock tmap. I'm installing the n20 next weekend.
2011 335xi e92
deep sea blue metallic
Mods: ps2; cobb fmic; vrsf ⬇️pipe; phoenix racing cp; injen cai; pure inlet; fuel it stage 2 lpfp w/ sensor; jb4 w/mhd e85 bef; meth 90/10 do3 and do7 nozzles. n20 tmap. Alpina flash. Fuel it port injection e50
