E90Ryan E90Ryan is offline
Default Your Experience with an Inlet Kit - 01-09-2016, 10:01 AM
As most of us know, we now have a few different choices of these kits as well as a price range of about $200-$1500. I'd like to ask those of you who have purchased a kit, what your honest review would be of it.
This is not a thread about who's better or worse because quite frankly I'm sick of seeing guys bashing each other on here and acting but the least bit professional.
All I'm asking is if you have purchased a kit, installed it, and have ran it, what you thought about the results. Dyno sheets are an optional plus.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 01-09-2016, 10:52 AM
Purchased a Precision Raceworks inlet kit.
http://www.precisionraceworks.com/
("hot side" -single silicone piece from air filter to turbo inlet)
Had someone else(who had already done a few) install for about $300.
Louder noise from turbos(whine) and Tial BOV (whoosh) is louder.
The stock turbos spool up faster.
Car is much quicker after than before.
No heat issues, but I do have Cobb FMIC.
Stock IC might not be enough to keep IAT in check.
No dyno or 1/4 mile times, sorry.
Note: my JB4 is currently removed for repair and I'm running stock flash.(and stock boost)
Car is still much faster than stock due to fast spooling.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Default 01-09-2016, 12:04 PM
I too installed precision racewerks on my car. I was one of the first to get it installed. Kit was just getting released so I have the original unit. Fit like a glove for being one of the first to be released. I installed them same time I did my turbos.
Louder spool
Louder bov sound (tial)
Boost is stronger top end, but might be because of the turbos 😁
Looks sexy in the engine bay
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Default 01-09-2016, 12:25 PM
First TFT kit.
Dyno included
http://www.n54tech.com/forums/showthread.php?t=28542
nitehawk nitehawk is offline
Car: e92 335i 6MT
Default 01-09-2016, 12:51 PM
I've always wondered if the car would be drivable on stock boost with upgraded inlets...if I were to sell the car, no way I'm paying labour to have them removed. So no overboost issues or otherwise with stock map?
dlp3719 dlp3719 is offline
Car: 2007 335i
Default 01-09-2016, 10:14 PM
Did RB inlets. Stock turbos. I have noticed...
Louder BOV
Holding 20-21psi almost all the way to redline
I haven't noticed a change in spool up.
2007 n54 e90 sedan (1/07 date), JB4 G5 ISO - Map 3, BMS DCI, BMS Trunk Tank Meth Kit - two nozzle - CM7/CM10, BMS OCC, MHD Trebilia Flash, e60 (5 gallons of 93 and 11 gallons E85), Stage 2 from Fuel-It, VRSF 7" FMIC, N54tuning.com V1 DP, ER Charge Pipe w/Tial BOV, NGK Iridium (one-step colder) plugs, N20 TMAP Sensor, RB turbo inlets, VTT outlets
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 01-10-2016, 12:48 AM
I purchased the TFT inlet kit and had them installed with Pure stage 2. The inlet kit is top notch in quality. I like this kit because it comes with an upper and lower chargepipe along with the coolant tank that needs to be moved to the drivers side. This kit performs very well and fitment was spot on.
I recently got the inlets and chargepipes powder coated gloss black. The raw metal look is nice but I prefer a cleaner/stealthier engine bay look.
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 01-10-2016, 02:02 AM
RB inlets + RB turbos. I had turbos running before inlets on. Inlets bring out the turbos spooling (with factory airbox) when just lightly tapping the throttle from 1800ish on. Then it gets drowned out by the engine. Sounds cool in drivethrus, etc where the sound echos.
Car: 2009 BMW 135i
Default 01-10-2016, 10:58 PM
Very drivable.
No over boost.
But boy do I miss my JB4.
I have MHD (BMS Version) so I flashed back to stock.
Thought about flashing a built in map, but was having problems connecting to Google Play store.
Decided I'd just leave as stock until I get my JB4 back.
Maybe I'll get used to the reduced horsepower and the increase in HP will be fun.
DennisPacMo's Avatar
DennisPacMo DennisPacMo is offline
Default 01-11-2016, 10:28 AM
I have clients with two Wedge Performance cars that are running the TFT inlets. Both cars are running stock frame turbos so the fit is comparable to a stock vehicle. The inlets fit well as does the charge pipe. I've purchased my own set with the charge pipe and Tial BOV for my own car but haven't installed them yet as I am waiting to do it with new turbos. I only want to drop the subframe once.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 01-11-2016, 11:33 AM
I also bought the precision raceworks inlets. I originally bought VRSF but asked for a refund, none of their stuff I've bought fits properly.
I've learned that this platform really does not reward you for saving money. It's better to just spend the money and get the "best" the first time around
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2009 BMW 135i
Default 01-11-2016, 07:23 PM
+1
Great choice the Precision Raceworks inlets!
VRSF can be hit or miss.
I like their *** and wheel spacers.
But PR really wins the inlet contest!
ksmyth's Avatar
ksmyth ksmyth is offline
Default 01-11-2016, 07:40 PM
+1 for precision raceworks. I can't rave enough at how available they are to support you via email. Great product too ;-)
09 335xi - 6AT - JB4 - hot side inlets - *** - MHD Flash - 7" IC - Fuel-It TBI
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 01-11-2016, 08:14 PM
I've purchase TFT inlets over the last summer, and I love them, the welds where great, the customer service was the best I've seen. I got a email every Friday until the item shipped on what's the status of my order. They even upgraded me to a polish finish because they where a couple days behind the estimated date. I installed these with the motor in and had no fitment issues.(don't recommend doing it that way) but all I hear now is the turbo spool and the BOV.
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
