stormchaser7's Avatar
stormchaser7 stormchaser7 is offline
Car: 135I
Default Misfires on multiple cylinders on WOT - 01-08-2016, 11:53 AM
Had the water pump go out on me at 73k. I have an aftermarket warranty so I took it to the dealer. They diagnosed misfires on cylinders 5 and 6. They opted to swap fuel injectors - no charge. Got the car back and it still misfires on WOT. They changed the coils on 5&6 and it still didn't fix the issue. Now I get misfires on 3,5,6. I am thinking HPFP. Pulled my JB4 before taking it in so I can't run any logs right now but I would put it back in and log if it helps diagnose the issue. What should I be looking for in the log? HPFP values?
Car: 135I
Default 01-08-2016, 12:41 PM
Fault codes I'm getting:
Mixture Control: mixture too lean 0029E0
Throttle angle - intake manifold Vacuum 002D2E
Misfire detection cylinder 3 in 2 firing order 0029CF
Misfire Cyl. 5 0029D1
Misfire Cyl. 6 0029D2
Misfire detection error summation 0029CC
Mixture control 2: mixture too lean 0029E1
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-08-2016, 12:46 PM
Just question, they replaced the injectors and coded it or just replaced the injector ?
Car: 135I
Default 01-08-2016, 12:49 PM
They replaced all 6 injectors and coded them to the car. They are the latest injectors. Priors were original to the engine (2010) Had walnut blast done in Novemver
psychosinmylobby psychosinmylobby is offline
Car: 07 e92
Default 01-08-2016, 12:57 PM
The 5 and 6 misfires stayed in 5 and 6. Sounds cylinder specific, it maybe plugs. How long have had the plugs?
Logs can tell HPFP pressure under load which can show it going out:
http://www.e90post.com/forums/showthread.php?t=1120250
Specifically FP H and FP L:
http://www.n54tech.com/forums/showthread.php?t=21269
Car: 135I
Default 01-08-2016, 01:30 PM
plugs were done in last June along with a complete set of new coils
Rushan's Avatar
Car: 335i E92 2009
Default 01-09-2016, 01:15 AM
The best way to plug back your JB and get a log which can really make things easier to troubleshoot on what's going on before the misfire
Car: 135I
Default 01-11-2016, 11:13 PM
Installed the JB4 and logged a few pulls. No engine misfires this time. Roads were wet so I only did a short run. Let me know if you find anything that looks out of sorts. TIA
omarmarji's Avatar
Car: n54 335
Default 01-12-2016, 12:01 AM
I had this problem , my o2 sensor was lose , but I ended up changing them both to fix it (upstream )
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
