trebila's Avatar
trebila trebila is offline
Default 01-08-2016, 10:29 AM
Originally Posted by Abdullahb
Took off my jb4 today...going back to cobb
Not the right choice to me
rhodesman's Avatar
rhodesman rhodesman is offline
Default 01-08-2016, 11:37 AM
Took off my jb4 today...going back to cobb ...or wedge
?? you post in the wrong thread? what does this have to do with inlets?
Engine/Drivetrain Modifications:
Trebila tune, xHP stg3, BMS OCC, BMS DCI, VSRF ceramic 3", ER Charge Pipe w/ Forge DVs, AMS Intercooler, Fuel-It Stg3+ LPFP, Pheonix Intake W/ PI, MMPe 1k's
Suspension:
Front & Rear 1M/M3 control arms & Subframe Bushings, MFactory YCW coils w/ Swift Springs
Exhaust:
Berk Street Performance Axle-back w/ straight Midpipes
Abdullahb Abdullahb is offline
Car: 2007 e90 335i
Default 01-08-2016, 05:13 PM
Because terry doesnt support inlets whatsoever ...might reinstall it later
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 01-09-2016, 10:28 AM
What type of support do you need for inlets?
Car: 2007 e90 335i
Default 01-09-2016, 12:36 PM
like how do i benefit from them..probably a backend flash for them.. or what to do in map6.. anything
Car: 2007 e90 335i
Default 01-09-2016, 12:37 PM
btw...
i reinstalled my jb4 today :p..
Car: 2007 e90 335i
Default 01-09-2016, 06:12 PM
So trebila which flasher do u use?
Default 01-09-2016, 08:50 PM
Abdullah, this is silly. Inlets allow your turbos to pull air with less restriction. The stock inlets are squeezed flat, especially in the rear. This has a restrictive effect on airflow so the turbos have to work harder, use more wastegate to achievepower levels the ecu calls for.
As a rule, the higher the boost, the more effective the inlets are.
You don't need to change tune or even tuning map, just install them. You'll notice that the turbos spool more freely and generate more power. How much depends on your turbos fuel, mods and boost level.
After installing my RB inlets I now hit 20 psi on 93 octane on a daily driving map. And it feels effortless. I can probably hit 25 on e85 blends. (Still tuning on that).
The way I would describe the effect is similar to catlezz d.ownpipes. But twice as much impact. Think of it this way. Your turbos just grew a size. That's what it feels like.
Grand_hustle17 Grand_hustle17 is offline
Car: 07 335i 6mt
Default 01-09-2016, 11:02 PM
Originally Posted by Texsquirrel
I'm not sure that Wedge will tune if you have JB4.
You would have to ask him.
I know that Trebila will.
There are probably others.
He's doing mine now lol
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 01-10-2016, 04:27 AM
Bump !
Do more with less !
Car: 2007 e90 335i
Default 01-10-2016, 03:12 PM
yeah but u put rb inlets.. im asking vrsf ones..
Nniftyfour's Avatar
Default 01-10-2016, 07:14 PM
They work exactly the same.
Without JB4 you MUST retune you will overboost bad if you don't. With JB4 you just set and forget.
Of course Terry supports inlets. Just use map 6 and set your targets.
Actually it's better as you can plug and play the N20 map sensor and boost over 21.5psi safely.
