dtrelle dtrelle is offline
Car: Bmw 335i
Default Log Review - 05-20-2019, 05:28 PM
Hi Guys,
Im running map 2 with 94 octane, im FBO excluding a catback exhaust i also have a stage 2 bucket less fuel pump and just installed precision race works coil back i am experiencing limp mode more after i installed the coil pack these are the logs i took today and was also wondering if anyone has had any problems seating the coils onto the plugs, i have the updated coil packs
Default 05-21-2019, 03:36 AM
Originally Posted by dtrelle
Hi Guys,
Triggered safety 2- afr lean
Bank 2 goes out of whack- based on log- looks like a hardware / sensor issue.
Could try an adaptation reset first, but Iíd replace
Car: Bmw 335i
Default 05-21-2019, 07:47 PM
Ok so i guess im going to order all new o2 sensors, what else do you think i should replace sensor wise?
'09 335i MT | JB4 G5 | Pump Gas BEF | STG2 Buckless Pump | ER CP | Forge DV's | ER FMIC | AR Design ** | NGK 95770 | BMS OCC | BMS Meth Kit | Precision Raceworks Coils
Default 05-21-2019, 10:03 PM
Iíve never been a fan of just replacing to replace.
If itís not causing an issue, IMO donít touch it
Car: Bmw 335i
Default 05-22-2019, 04:22 AM
Sorry Iím a little confused what hardware / sensor issue do you think is causing this
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-22-2019, 11:06 AM
He said earlier Bank 2,
You said you were gonna replace all,
He said heís not a fan of replacing just to replace, basically just replace the sensor thatís giving you the problem
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 05-22-2019, 11:50 AM
Bank 2 o2 sensor- should be $90-$120 or so on amazon
Car: Bmw 335i
Default 05-22-2019, 12:01 PM
I guess I just figured if the bank 2 sensors went bad maybe the bank 1s will soon and if Iím there to replace 2 Iíd might as well replace all 4
Car: Bmw 335i
Default 05-22-2019, 12:05 PM
Do you recommend going with the oem o2 sensors or maybe upgrading to NTK or adv sensors
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-22-2019, 12:25 PM
"Sorry Iím a little confused what hardware / sensor issue do you think is causing this"
I get what you are saying..... but you did say you were confused on what sensor he was talking about.
If it makes you feel better then change all of them
07 E90 AT - xHP
FBO
Hybrids
