GreenE92Matt GreenE92Matt is offline
Car: 2007 335i
Default Interpret this log? - 03-10-2019, 09:20 PM
I logged this in Houston TX, With about 86% Humidity, No Traction loss or any kind of slippage. Please Let me know if theres something i should be worried about or something isn't adding up. Thank you.
Default 03-10-2019, 10:12 PM
Can you provide a little bit more info about your setup? Mods, Fuel etc
Car: 2007 335i
Default 03-11-2019, 08:28 AM
BMS DCI, VRSF *********, VRSF Chargepipe (With a Turbosmart BOV), Running 93 Pump Gas.
Default 03-11-2019, 11:34 AM
Boost looks ok.
Timing takes a bit of a dive- looks like a combo of the weather, and likely pump gas.
If you have the means, Id flash the pump BEF & enable 6cyl timing
