WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default Best Jb4 map for me ? - 09-29-2017, 02:00 AM
What is the best Jb4 map for me ?
12’ F10 535i AT | JB4 | BMS Intake | VRSF 3.5" Kittenless Down-Pipe | VRSF Charge-Pipe
i am thinking between Map 1,2,5 ?
Edit:
My Fuel is - 95'octane
Default 09-29-2017, 08:14 AM
I'd imagine map2 but "95 fuel" is probably like our 91 RM2... Log it and we can verify its running well for you.
Default 09-29-2017, 08:45 AM
I'll log it on map2 and on map5
And share the results
Thanks terry
Default 09-30-2017, 03:50 AM
@Terry @ BMS
Do the runs have to be WOT runs on every map ?
or do i have to just drive normally on every map and post the logs and you can tell me the best map i need to use ?
Default 10-01-2017, 12:21 AM
Here you go...
http://www.n54tech.com/forums/showpo...21&postcount=1
Default 10-01-2017, 01:17 AM
This doesn't answer my question
I know how to log
But my question is when logging
Do i have to use full throttle
Or normal driving ?
Because terry told me to log , for him to know what is the best map for me..
So i wanted to know should i log in map 1,2,5 in full throttle ? Or just normal driving
keyap keyap is offline
Car: N55 135i
Default 10-01-2017, 03:16 AM
Grab 1 log on each map - one on map 1, one on map 2 and one on map 5.
Defeat traction control and do the runs going WOT (full throttle) in 3rd from ~2500 rpm to redline. Then post the three CSVs.
[B]
Default 10-01-2017, 03:19 AM
So i have to turn off the traction control fully ?
Car: N55 135i
Default 10-01-2017, 03:26 AM
On my E, you press the button once, but don't hold down.
[B]
inevitab1e's Avatar
inevitab1e inevitab1e is offline
Car: 2013 N55 135is
Default 10-01-2017, 06:54 AM
I'm pretty sure they want you to hold down the traction control button to turn it off completely for the runs.
2013 E82 135is N55 JB4-BEF FBO
Default 10-01-2017, 07:02 AM
Can terry confirm the right steps to log ?
Shod hold down till full traction is off or just press once .?
And on what gear shold we be on ? Since i have the 8AT gear
Car: N55 135i
Default 10-01-2017, 07:44 AM
TBH - it only matters if it's interfering with your 'run'. If you feel happier then wait for ANOther and/or someone at BMS/FuelIt etc to chime in.
[B]
Default 10-02-2017, 11:08 AM
Just press it once. 3rd or 4th gear will be fine.
Default 10-10-2017, 01:50 AM
@toome Shared this with me
- Find a clear stretch of road (no cops and good pavement, as well as enough space to hit speeds of ~80mph "safely")
- Turn traction control off, but leave DSC on unless you're crazy. Reason to do this is the DME will pull timing when you break traction with TC on which isn't good for logging.
- Start logging right before you're about to do the pull. I suggest using manual logging instead of only at WOT
- Get the car in 3rd gear at around ~2500k RPM and then floor it until redline. You can also go through 4th gear as well but it isn't necessary.
- Come down to a safe speed and stop logging
Thanks toome for the great advice on how to log
