Boss86 Boss86 is offline
Car: 2007 Bmw 335i
Default Oil leak please HELP! - 11-17-2016, 10:39 PM
Hey guys, I have a 07' 335i n54 **'s dci, jb4 and after doing some logs with map 6 doing some custom e85 tuning everything was great! I hit 0-60 in 3.4 secs and a 1/4 in 11.8 and I was ecstatic! but then later on that day at the car wash my serpentine belt broke and I noticed oil everywhere on the front of the engine so I drained the oil changed the oil filter housing gasket, replaced the belt the tensioner pulley and idler pulley did the oil change and coolant flush to find oil leaking down the front of the motor still. I don't see the valve cover leaking or the head gasket leaking. I thought maybe pieces of the belt was in the engine but the car starts fine drives fine and don't really leak oil until you push it, it's not getting a check engine or nothing! No tapping noises at all so maybe the belt isn't in their. Anyone have some ideas? I open the oil cap and no milky residue when I drained the oil no milky residue. When doing the coolant I didn't see any oil and no smoke out the exhaust so I'm lost! PLEASE HELP ME!!!
Car: 2007 Bmw 335i
Default 11-17-2016, 10:43 PM
I also took out the pcv valve shook it and it rattles, cleaned the pcv hose sensor on it and cleaned the pcv valve itself with some throttle body cleaner.. it still shakes on the inside so I figure it's good, I'm still scratching my head on this..
vitan's Avatar
vitan vitan is offline
Car: e92 N54 335i
Default 11-18-2016, 12:20 AM
I assume your engine hit the subframe. Did you check the oil pan?
07 335i
J.J4ck0wsk1 J.J4ck0wsk1 is offline
Car: N54 335i FBO Meth
Default 11-18-2016, 12:48 AM
Is there damage around the power steering pulley area? Was there any part of the belt missing by chance? Did you take a picture? Let us know
08 E92 335i Alpine White On Coral Red 6 Speed
BMS DCI+Aquamist METH Kit+MHD+VRSF+AR25 Resonators+HPF IC+AA CP+AA BOV+SSK+KWV1+Mfactory SMFW+550i/335is Clutch+BBS LM Reps+Diff Brace+M Performance Shift Knob+RB PCV+HPF OCC+NGK
Mustang Dyno: 426whp/484wtq on E30/Meth/Stock Inlets+Outlets/Procede Only @ 18psi
Current Estimate: 450/500 on E50 Custom EDC Tuning MHD Flash @ 21psi
Car: 2007 Bmw 335i
Default 11-18-2016, 06:53 AM
I will take some pics I just tried to up load the video I took but I keep getting errors and it's not uploading for whatever reason.
Car: 2007 Bmw 335i
Default 11-18-2016, 06:58 AM
And yes some of the belt was missing pieces was on the bottom cover but not enough for me to have all the belt pieces, I'd say 30% maybe a little less was missing, power steering isn't leaking, the reservoir needs replacing around the top does have residue but it's not even close to the engine
Car: 2007 Bmw 335i
Default 11-18-2016, 07:06 AM
The oil pan isn't leaking I did spray gel degreaser on the pan and the rest of the car underneath all is still clean other then what's blowing back when driving since it is running down the front of the motor,I think from the side of where the tensioner pulley is in that upper crevices towards the left standing in front of the car. It goes down to the crank pulley and when the car is running the belts get it all over the bottom part of the engine and part of the alternator too
Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 11-18-2016, 09:07 AM
How about the oil cooler housing. Two gaskets there that are prone to leak.
Car: 2007 Bmw 335i
Default 11-18-2016, 10:42 AM
Mine don't have a oil cooler haven't added that yet
RCB RCB is offline
Car: E61 535XIt
Default 11-22-2016, 06:29 AM
From everything I've learned regrading serpentine belt failures it sounds like the front main seal should be the first thing in question. I know you said it's running down the motor but is it possible that it's getting flung up the motor off of the crank pulley/belt? Otherwise maybe check vanos seals.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
