Grand_hustle17 Grand_hustle17 is offline
Car: 07 335i 6mt
Default Virtual dyno guys - 01-05-2016, 09:28 PM
Ok guys i cant seem to get the settings correct on my virtual dyno. Had it once where it seemed very close to correct and made a few adjustments with david @ trebilia whos working very patient with me. Just would like to see someone use my csv and upload it into their virtual dyno to see if we got comparable numbers.
http://www.***********/u/grandhustle1...g=0&data=1-4ch
Mostly interested in seeing my curve as my last one i lost 118whp from peak to redline.
Anyone willing to create a graph?. Thanks in advance
Edit: pulls were done in 3rd gear and a lil bit in 4th
nyt nyt is offline
Car: 335ix
Default 01-06-2016, 10:03 AM
You'd need to provide tire dimensions at a minimum.
Jt0407 Jt0407 is offline
Car: Bmw
Default 01-07-2016, 12:34 PM
You can only do a one gear pull.
csu87 csu87 is offline
Car: 09 335xi
Default 01-07-2016, 02:24 PM
like mentioned on the other forum, do all your VD pulls in the same locations on a flat road. Then at the very least, get an accurate tire measurement and weight for the car, or get a real dyno and set up the VD to match.
Car: 09 335xi
Default 01-08-2016, 07:45 AM
your avg_ign is in the 20s in that log, when the range is only 0-6. get a new log and dont modify the csv file.
Car: 07 335i 6mt
Default 01-09-2016, 10:48 PM
I dont even know how to modify the csv file :
Car: 07 335i 6mt
Default 01-09-2016, 10:55 PM
Trying to load csv
6mt sedan non sport wheels 255/45/17 stock heght
