Starscream Starscream is offline
Car: E92 335i
Default M3 Cluster retrofitted and JB4 options don't match the speedo/tach, How to fix? - 04-09-2015, 08:06 AM
Ok so maybe my thread title doesn't make sense,
I have an E92 335, I have an M3 cluster that I've coded to my car and new EPROM burned etc etc,
All good,
Now the only thing thats not lining up perfectly is the JB4 steering settings
Then you press the 2 steering wheel buttons down and go into the menu it overshoots the speedo and tach thats actually in the car and goes to the position of the speedo from the stock 335,
So I'm having to count how many presses rather than actually being able to see what setting I'm on,
Is there anyway of letting the JB4 know I am using an M3 cluster so the needles line up correctly?
swat's Avatar
swat swat is offline
Car: 07 335i
Default 04-09-2015, 08:12 AM
All good,
Doubtful as that isn't even close to any cluster we'd have. I was going to say the 1M setting maybe, but then remembered the M3 has a tach that goes to 9000 and speedo that goes to 330. So i don't think you'll have any luck!
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Car: E92 335i
Default 04-09-2015, 04:28 PM
That sucks
Oh well I've been counting the amount of button presses for a while now anyway so I'm getting used to it
E90Ryan E90Ryan is offline
Default 04-10-2015, 10:59 AM
Maybe when you get it figured out, post a conversion list. There could be some more folks with the same issue..
maxgohan maxgohan is offline
Car: e90
Default 04-10-2015, 02:43 PM
sounds like it'd have to be coded into the next firmware to fix that issue....
Car: E92 335i
Default 04-10-2015, 02:47 PM
Yeah I can't be the only guy running an M3 cluster and a JB4
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 04-10-2015, 03:27 PM
i have the m3 cluster as well that goes to 200mph and ive spoken to terry about the same thing a while back. he said it was close enough and therefore not worth changing. we just need to count presses. you'll get used to it
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 01-07-2016, 12:03 PM
Any update on this? It is impossible to read codes with my M3 cluster and hard to do any adjustments in menus on the upper MOH scale as the scaling changes above 80.
riva riva is offline
Car: 335XI
Default 01-07-2016, 12:23 PM
No way you can read codes on the fly... Simple solution go purchase the bluetooth jb4 kit and do everything from your phone. But I'm sure if enough of us show interest to terry he will do something about it
Default 01-07-2016, 12:31 PM
Just find the closest menu5 match. Not enough people have this to justify custom JB4 programming for it. At least yet.
