Benny335i's Avatar
Benny335i Benny335i is offline
Car: E93 335i
Default N54 335i, Taken a few seconds longer to start.... - 11-03-2015, 03:58 PM
Hello all,
New to the forum, so very sorry if this has been asked before.....
My 2008 E93 335i sometimes takes a bit longer than normal to start....
I have recently had a full service and put in NGK Plugs 5992 Gapped to 0.022 which is for Tuned cars as its booked in at Evolve on the 18th.... Do you think the start up is due to plugs or the dreaded HPFP?
Thank you very much for your time...
Ben
duracell8 duracell8 is offline
Car: 2008 535i
Default 11-03-2015, 08:25 PM
Long crank 4-5 sec= bad hpfp
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Benny335i's Avatar
Car: E93 335i
Default 11-04-2015, 01:48 AM
Great..... How much are?
Car: 2008 535i
Default 11-04-2015, 05:59 AM
Covered under extended warranty 10year/120K miles
AndersS's Avatar
AndersS AndersS is offline
Car: 335I Touring aut. 2010 N54
Default 11-04-2015, 07:27 AM
Do you notice any smell of unburned gasoline after startup?
I my case, it was a leaking injector. Not the Hpfp.
2010 E91 335I n54 Alpina B3 flash - JB4 - dp -BMS CP -Wagner FMIC Evo2 Comp. - RB Inlets - PURE Stage 2 - EOS PI - DV Irinium 5992 -Fuel-IT Stage3 Lpfp - KW Var1.- Trebila Performance flash E50
Benny335i's Avatar
Car: E93 335i
Default 11-04-2015, 10:25 AM
Yes strong smell of fuel on start up...
Blue Demon Blue Demon is offline
Car: 335I
Default 11-04-2015, 10:50 AM
Thanks for the thread Benny335i, began with the same issue two days ago
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 11-04-2015, 12:36 PM
My vote is injectors
09 335 - 6266
07 335i - 6870, E85 - SOLD
eaton18spd eaton18spd is offline
Car: 2008 535xi
Default 11-05-2015, 07:12 AM
Pull the plugs and see if any of them are wet and smell like fuel. if you find a wet one, your injector is most likely leaking. Also if it is the pump BMW most likely won't replace it under warranty unless you have the latest injectors, at least that is what i have been told.
psychosinmylobby psychosinmylobby is offline
Car: 07 e92
Default 11-05-2015, 07:28 AM
Do you know if it is better to check the plugs after driving or when it is cold?
Car: 2008 535i
Default 11-05-2015, 08:57 AM
COLD. If you do it warm, the fuel will evaporate.
Milan's Avatar
Car: 08 335xi
Default 11-05-2015, 10:31 AM
If your injector is leaking you can tell by looking at the plug, regardless of if it's warm or cold.
It's always a good practice to do plugs on a cold motor though.
09 335 - 6266
Benny335i's Avatar
Car: E93 335i
Default 01-07-2016, 08:04 AM
misfire on start up from cold now and lumpy idle... I will get injectors flow tested.... then I best get my wallet out haha
Milan's Avatar
Car: 08 335xi
Default 01-07-2016, 09:41 AM
There is nothing wrong with the flow, it's their ability to not flow. If you understood how a direct injection injector worked you would realize that a flow test is a waste of money.
Throw away the stock injectors, replace all of them with revision -12, code them and be on your way.
09 335 - 6266
bk335xi's Avatar
bk335xi bk335xi is offline
Car: 335xi 6MT
Default 01-07-2016, 09:51 AM
Don't waste your time. It's 100% the injectors. Buy injectors from rock auto, they're $120/ea and index 12.
+1
08 335xi 6MT | FBO
Benny335i's Avatar
Car: E93 335i
Default 01-07-2016, 10:09 AM
Thanks guys.... Anywhere in UK I can buy them? Thanks again
bk335xi's Avatar
Car: 335xi 6MT
Default 01-07-2016, 10:28 AM
http://www.rockauto.co.uk/catalog/mo...nid=513&jpid=0
77gbp.
08 335xi 6MT | FBO
