(#551)
Default 05-09-2015, 07:22 PM
Originally Posted by Rushan
For the latest MHD BMS flash should we use the same xdf file from the BB flash 1st page for the ije0s.xdf?
Yes the XDF files are the same for MHD and BB.
BeGooD69 BeGooD69 is offline
Default 05-09-2015, 07:49 PM
Ok. So Wut s the plus in the MDH flash then? I like to see why to pay for the same free?
Default 05-09-2015, 07:52 PM
For OEM turbos there isn't a huge benefit. For larger than stock turbos the race logic in the MHD makes for some nice improvements especially for automatic cars.
Default 05-09-2015, 08:00 PM
Oh yay. So that is all benefits for me. At 6466g2 and AT with valvebody and torque converter upgraded. (Until the rest give up)
So where do I get it and how much. I have iPhone and laptop. Wut platform does it run?
Default 05-09-2015, 08:02 PM
Terry, talking to Payam, I m coming to L.A. Mid -end june. Maybe I get to meet u guys. And dyno there. BcZ my number here in El Paso did not impress me on my twin-turbos.
pianoman224's Avatar
pianoman224 pianoman224 is offline
Car: 2008 BMW 335i
Default 05-10-2015, 10:25 PM
Im looking into flashing via this platform and upon testing the program I had a couple errors pop up in regards to the "backup the ecu" option. There were 2 different messages that popped up at different times and I will list them below.
1) "ECU is read-protected"
2) "ECU reading exception
Connecting...."
I have not purchased a license yet so this may be why I am getting these messages, I just wanted some feedback before I shell out 79 bucks for something that may or may not work.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 05-11-2015, 07:19 AM
I'm pretty sure you are correct...The MHD flasher is superb...worth every penny!
spain4065 spain4065 is offline
Car: e82
Default 05-11-2015, 12:32 PM
Lots of interest in this, has anyone taken this to the rollers to see the numbers?
Car: 2008 BMW 335i
Default 05-11-2015, 10:34 PM
I am not sure if anyone has tried this yet, but I thought I'd share my experience.
I wanted to do the BMS pump flash but did not have a BT cable or an android device. Having run various coding flashes and transmission flashes via XP running through VMware on my macbook, I decided to setup an android operating system through VMware on my laptop.
Long story short I got it up and running, copied over the latest BMS flash files, plugged my INPA cable in, bought the 79 dollar license to flash, and prayed to god that I wouldn't brick my DME. 33 tense minutes later and I had a car that no longer goes into limp mode on WOT and pulls like a freight train on 91 oct!
It's worth noting that I went to walmart and bought a ~70 dollar battery charger just to be sure it didn't drop connection mid flash.
I'm very pleased with the results and for those of you who do not have a BT cable or android device, this method worked flawlessly for me. I may be the only person that has flashed like this, so I wanted to let you all know that it worked just fine.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 05-12-2015, 08:55 AM
What's the best flash file to start with when running RB turbos w/VTT inlets and e50?
Fast335i's Avatar
Fast335i Fast335i is offline
Car: 07 BMW 335i
Default 05-12-2015, 10:54 AM
+1.....and is there when that scales for n20 sensor?
2007 BMW 335i...M2 exhaust...Macht Schnell DP's...VRSF 7" FMIC...MM Performance inlet system.....VRSF Chargpipe with Tial BOV....MFACTORY LSD....MHD e60. Wedge tunING.........RB Stealths......N20 Tmap upgrade.....Steve Stage 2 450......H&R Race lowering springs...MT ET Streets 265/40/18 rear.....NGK 5992
DV135i's Avatar
DV135i DV135i is offline
Default 05-12-2015, 11:08 AM
Which battery charger did you get?
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 05-12-2015, 12:24 PM
In order to flash using MHD, does the Android device have to be “OTG Compatible” or can any Android device be used regardless of if it’s OTG Compatible or not? I understand that in either case you would still need the DCAN and OTG adapter cable.
mastawyrm mastawyrm is offline
Car: 2011 335is, 2002 540
Default 05-12-2015, 12:33 PM
Yes it does have to be. OTG compatible basically means that the device has the hardware to actually be a "host" device like a computer rather than just an end device like a keyboard/mouse/DCAN cable.
If you have an Android device that you'd like to test first, OTG cables are super cheap or can be built with a little soldering and a sacrificial usb cable, then you can just plug in a mouse and a cursor should be on screen almost immediately if your phone/tablet supports OTG.
Fast335i's Avatar
Car: 07 BMW 335i
Default 05-12-2015, 04:31 PM
Ok so I downloaded the module so I can flash. When I clicked on jb4 backend flash it take me to sub folders of my phone. Where can I get to download the flashes so I can flash using the mhd....
specifically an e60 flash. .....or e50...as I have stock hpfp and have the N20 sensor and want to get close to 600 who
Car: 2008 BMW 335i
Default 05-12-2015, 05:04 PM
I used this battery charger from walmart. Worked great! Kept voltage at a steady 12.12 during the entire process
http://www.walmart.com/ip/Schumacher...arger/25955538
Car: 2008 BMW 335i
Default 05-12-2015, 05:05 PM
There is also an app on the google play store that can check your device's OTG compatibility.
AUbeast86's Avatar
Default 05-12-2015, 06:08 PM
Just tested. Tab 4 is not OTG compatible. Which tablets are OTG compatible and have Bluetooth 4.0? There is limited to zero info on which ones have both.
zach1328's Avatar
zach1328 zach1328 is offline
Car: 535i
Default 05-12-2015, 06:09 PM
Has anyone tried flashing an i8a0s DME without the battery charger? The estimated flash time is only 16 minutes vs. over 30 minutes for later DME's.
If I try and it bricks the DME, is it as simple as buying a battery charger and reflashing my ECU back to stock (with my backed-up file) or would there be a lot more work involved with a bricked DME?
2007 335i - JB4 + MHD Pump BEF, DCI, VRSF **, MMP stock location inlets/outlets, XHP Stage 3, TC Kline SA, M3 F/R control arms
2008 535i
N54
zach1328's Avatar
Car: 535i
Default 05-12-2015, 07:16 PM
I ended up buying a cheap $25 battery charger. It says in the description, "This battery charger is designed to slow charge wet cell, lead acid 12 volt batteries".
Does that sound like it will work with the e90 battery? Sorry if this is a dumb question, but I know nothing about car batteries.
2008 535i
N54
boostninja boostninja is offline
Car: 335is
Default 05-12-2015, 08:57 PM
Any updates on INA0S?
DV135i's Avatar
Default 05-13-2015, 07:09 AM
I have the samsung galaxy note 4 which is OTG compatible and has bluetooth 4.1.
I'm surprised that one doesn't have it. Unfortunately I don't know any good way to know what does and does not have it beyond searching " 'model' OTG capable " although I wouldn't be surprised to find out someone compiled a list somewhere.
I can say I've used OTG on my original Motorola Xoom and I actually flash with my Nexus 6.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 05-13-2015, 07:26 AM
I use my Galaxy Tab 3 with MHD no issues.
Default 05-13-2015, 10:54 AM
Does anyone know if the "backend flash" and "custom flash" functions actually do something different? I noticed when I tried to use the custom flash function on a slightly tweaked bms backend bin it gave me the message that I need to purchase the higher boost module but I was still able to flash it with the backend flash function. I just wonder if it's treating them differently somehow or if this is a loophole to get around buying the module. Or did I copy some kind of backend identifier to my original bin when I was copying changes into it?
