(#7676)
v1nc86 v1nc86 is offline
Car: E90 335xi
Default 10-01-2013, 06:13 AM
will installer 27.2 iso later today!
2008 Jet Black 335xi E90 6AT | Alpina B3 TCU Flash | BMS Backend 7/1 Pump Flash | JB4 G5 ISO 31.5 | BMS DCI | BMS CP | VRSF 5" FMIC | BMW Performance Exhaust | VMR V718 / Kumho | Best 1/4 mile: 12.37@110.4 MPH | Top speed: 0-270 km/h | YouTube
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 10-01-2013, 06:37 AM
Yes I can version them but its a lot of work to also change the links to the files in the first post.
You could set the link to a folder, then just drop what files you want to share into the folder. Make sure that you allow the folder to have 'list' permission.
BTW, I usually don't comment on ISO updates, but WOW...so smooth...
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 10-01-2013, 08:05 AM
Does anyone use the 4.2 option?
Are you getting any benefit? or, what cases is beneficial when not using the target of the dme?
Time is the best teacher
Car: E90 335xi
Default 10-01-2013, 08:09 AM
interested in the answer...
BrewRifle BrewRifle is offline
Car: 2009 135i
Default 10-01-2013, 08:19 AM
Same here. Is that for those running G5 ISO only or is it for those running a BE flash as well? Which is better when running solely with a G5 ISO + bolt ons and no custom flash?
The Die's Avatar
The Die The Die is offline
Car: 2010 335 Xi
Default 10-01-2013, 11:34 AM
Originally Posted by HeavyMetalRocker
Are we ever going to be able to do the backend flash without the cobb? I can't justify $800+ nor can I afford it for that...
This is a troll, right? It has to be. No one can possibly be that blind.
-Greg
2010 335xi 6AT | Black Sapphire Metallic | Black Dakota Leather | Alpina B3 Flash | BB Open Flash | JB4 | BMS DCI | Tons more to come...
Live in Central Ohio? Looking to have some coding done? Shoot me a PM.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-01-2013, 11:55 AM
If for some reason..... say your traveling and can't get E85 or you run out of meth....... you want to be able to use the lower boost targets set by the JB4.
AWil335i's Avatar
AWil335i AWil335i is offline
Default 10-01-2013, 04:57 PM
I do - feels like it's a little bit smoother on low throttle, especially if you have menu 12 up high to avoid WG rattle.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
#teambimmer #teambimmer is offline
Car: 09 335i xDrive Coupe
Default 10-01-2013, 05:25 PM
Just out of curiosity what are your menu 12 settings?
09 Space Grey e92 335xi 6AT + Alpina TCU Flash // JB4 G5 ISO + Wedge Flash // BMS DCI // AE Exhaust // VRSF ********* // Helix FMIC + Lower CP // ER CP // ONEighty AE // 6k HPB HID Fogs
BCeagle08's Avatar
BCeagle08 BCeagle08 is offline
Car: 335i 6MT E92 Xdrive
Default 10-01-2013, 07:08 PM
New thing for me in 27.2, hasn't happened every in any other firmware version, but has happened about three times in 27.2
During WOT runs, as I near redline the car will do a very quick stumble and lose power. All three times this has happened in third gear (on MT) but that could just be a coincidence. Also, I get more boost in third gear than first or second, for whatever reason. Not sure if that has anything to do with it. I run about 40-50% E85 and the rest 93 octane.
Anyway, a quick check of the engine maps reveals that this stumble is because JB4 has switched from map 5 to map 4 during the full throttle run. The second and third time the stumble happened to me, I immediately checked the map settings and saw that it had switched to map 4 on me, so it's definitely doing it during the WOT runs.
I do not throw any codes, and switching the car back to map 5 works just fine.
Is this some sort of bug, or is it a JB4 safety feature? Any idea? I would post logs, but I don't have an extension for my USB cable at the moment.
jim66 jim66 is offline
Car: 335is
Default 10-01-2013, 07:42 PM
27.2 is doing same thing for me and my friends car, both 335is w/dct.. 3rd gear car loses power and JB4 goes in to map 4...my car does this in map 2 and map 6
i know i know...get a log. working on it.
Default 10-01-2013, 08:02 PM
It will do that if AFR goes too lean, or fuel pressure drops below 7, among other causes. There is a setting "FUD = 17" that is designed to improve fueling on 335is models. You may need to enable that if turns out to be fuel trims related.
BCeagle08's Avatar
Default 10-01-2013, 09:05 PM
I'll have to run some logs then to see if that's the case, but I imagine it's fueling. Car is 60k miles and is running almost 50/50 e85/93 octane on the stock fuel pump. I imagine I'll have to upgrade the fuel pump soon.
Default 10-01-2013, 09:06 PM
ISO 27.3 Notes
1) Corrected a bug preventing throttle trimming from properly engaging in response to boost over target conditions.
JayD JayD is offline
Default problem downloading 27.3 - 10-02-2013, 05:06 AM
Terry, when I try downloading 27.3 my computer says it can't download the file. I can download other items except that. Any issues that you know of?
Jay
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 10-02-2013, 05:38 AM
Same thing here
2008 e92/MHD Wedge E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
sirfredi's Avatar
sirfredi sirfredi is offline
Default 10-02-2013, 05:55 AM
Jay
Np problems. Try again
Robert's Avatar
Car: bmw
Default 10-02-2013, 06:22 AM
It's not your car it's the 27.2 doing it. That is why I am going back to 25. Same mods same fuel same map. Had 0 problems
Car: 335is
Default 10-02-2013, 06:27 AM
Is there a list of Future Use = list somewhere? seems i would want improved fueling.
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 10-02-2013, 06:32 AM
http://www.n54tech.com/forums/attach...2&d=1380221470
|2007 E92 SGM 335i|
Cobbv3 BMS DCI & OCC VRSF *** & FMIC E85 Custom Backend & Alpina TCU flash ER CP RB PCV+Cap
Walbro 255 Rohana RC5 19s Nittos 555 245/275 Cyba Scoops LUX V3 M3 Cowl ST Coils LCI Tails
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 10-02-2013, 06:45 AM
Loaded 27.3 this morning. Car is adapting very well without issues. Boost still hitting high 17s on map 5. Have to run some logs today to check Map 3.
Autobahn.......its what's for dinner!!!
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 10-02-2013, 07:38 AM
Is this something you should do as a matter of course with a 335IS or do you need a fuel issue first?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
Jelly335 Jelly335 is offline
Car: N54 335
Default 10-02-2013, 07:40 AM
so a few days ago got my g5iso installed.im on map 5 and been only hitting like 11-12lbs of boost then sometimes spikes up to 14-15lbs.it feels very slugish and loss of power.also i notice my exhaust note changed and is not as loud( ******* DP and Catback exhaust) the right side seems louder. anyone have an idea what it can be? no cel and jb4 is full communication with steering.
Default 10-02-2013, 08:04 AM
If you need tuning assistance post a log to the support section.
Generally only if trims are maxing out.
