(#5801)
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 12-04-2012, 12:11 PM
Originally Posted by BMWDon
TBE = turbo back exhaust
I may have to look into this then
ask to a member id: Ocean
He will give you a good feedback.
najin23's Avatar
Car: 335i CDV
Default 12-04-2012, 12:16 PM
How does TBE sound? I assume that it has a pretty good deep low tone. How about emission test? Does your state require emission?
jwhit012 jwhit012 is offline
Default 12-05-2012, 09:21 AM
Just installed jb4 on my 135, added 5 gallons of e85, and I'm amazed. I would love to post a dialog of my numbers to get opinions about how my car is performing. I have no idea what I need to do, I have the USB cable, so do I just plug it up to my laptop? I have an apple , does that matter?
srSheepdog's Avatar
srSheepdog srSheepdog is offline
Default 12-05-2012, 11:59 AM
Originally Posted by jordan313
im 10-0 against GTR's and Z06's aswell
Were they aware that you were "racing" them?
Antonio91 Antonio91 is offline
Default 12-05-2012, 12:46 PM
im a but confused but can someone correct me? when using the NLS you set the
Bogfix= 0
or do you just leave it at
Bogfix= 100
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 12-05-2012, 07:25 PM
Something weird happened tonight. I was out and decided to get on the car a bit. On my 2nd run, the service engine soon light blinked a few times. Out of the 6 runs I did, the light showed up twice. When I went to see if there were any codes, none showed up. Anyone have this issue? What could it be?
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 12-05-2012, 07:30 PM
Gonna run map 7 on my FBO 335i, on ms109 race fuel. Anything I should know other then turning up the overboost safety to 20..
2014 F10 535i N55 PWG
Default 12-05-2012, 11:00 PM
It's a very aggressive map @ 18.5psi target, but as long as the car is in good shape and you have straight MS109 it should be OK.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 12-05-2012, 11:04 PM
Gonna give it a shot next week.. I probably wont have logs since its gonna be for a few friendly races, but I will come back with the results on map7
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 12-06-2012, 12:14 AM
So T, you're saying that even with FBO and MS109 that our cars should be OK to run map 7? If so, when is it definitely OK to run map 7 (on stock turbos)? I ran map 7 frequently with the G4 board but my G5 board is in route so I'm curious if I shouldn't be run map 7 and stick to map 5?
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
najin23's Avatar
Car: 335i CDV
Default 12-06-2012, 04:22 AM
Well... .disable the autodelete, then read codes when the next sel pops up. Just fyi......this engine with many wot will show various codes. I've had many already and mostly I ignore. I especially had many misfires with sel or cel on, and they simply go away along with symptom.
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 12-06-2012, 07:26 AM
Depending on how many times it flashes could be overboost safety, lean run protection, or misfires.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 12-06-2012, 10:57 AM
Have 15 installed.....the low rpm speedup is gone, nice work
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 12-06-2012, 11:44 AM
ultmxp's Avatar
ultmxp ultmxp is offline
Car: 335is
Default 12-06-2012, 02:08 PM
Terry, can you post the updated pic of the spreadsheet for the command mode? Its handy to keep it on my phone.
2011 E92 335is 6MT - Everything except Logic7 but MusicarNW + Technic FTW!
Mods - JB4 G5, Cobb BMS Flash, 5" ETS IC, Injen Intake, AR ***, ER CP, Forge DV, M3 suspension kit (front), H&R Sport Springs, Performance Shift Knob (adds 50whp!)
boostboy boostboy is offline
Car: 2009 E92 335i
Default Should I go ISO on my new JB4 G5? Any downsides??? - 12-06-2012, 02:35 PM
I just recently bought and installed JB4 G5 new from BMS. I understand that to run isolated boost which does not involve the DME, I cut out the two diodes and load up new firmware (I assume I would use the latest version available).
From the reviews on this thread, it seems like I can't find a reason to not do this other than the ISO control is still in alpha testing.
Any reason for me to wait or should I just take the plunge? It seems like it would not be feasible to reinstall the diodes if I wanted to revert back.
My car is CPO for two more years and I have DCI. Until out of warranty, I don't plan any other mods (DP's, FMIC, etc.)
jordan313 jordan313 is offline
Default 12-06-2012, 03:06 PM
Why wouldn't you? ISO is the future and if you look at the G5 sticky, Terry said they're focusing on ISO now so no more normal G5 firmware updates
Car: 07 e92
Default 12-06-2012, 03:28 PM
From what I remember it flashed 3 times. There were no misfires. Only time it happened was, when I was doing about 15 mph and got on it. I have an auto transmission, and when it downshifts few seconds later the service engine light flashed. I was thinking, it could be to much load, or boost down low and thats what caused the light to flash. The car drove perfect, and on other runs it was fine. Maybe I am making it a big deal, when it really is not. I did not know about, if how many times SESL flashes and what it means. I didn't know the amount of time it flashes, it indicates something. I should not have misfires, I only have about 2,500 miles on my plugs and coils. I have a new engine with same amount of miles.
Car: 2009 E92 335i
Default 12-06-2012, 03:48 PM
No reason I can think of other than waiting for alpha test "bugs" to get worked out. I gues they will get worked out in later revisions of firmware which I can download though.
Let me put it this way - has anyone noticed ANY bad effects of ISO?
Jnat Jnat is offline
Car: 09 335xi
Default 12-06-2012, 04:25 PM
I feel like each revision has made light to medium throttle boost application smoother, esp right after shifts. I'm running 15 right now and it's the smoothest yet, great job to Terry.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 12-06-2012, 09:02 PM
You have to load the latest G5_ISOxxx.hex software, never the normal G5 software.
Just do it..... you will like it. IF you are careful, you can revert back to normal Non-ISO software but you won't want to.
cslpower cslpower is offline
Car: 08' 335i E92
Default 12-07-2012, 06:27 AM
I stuck a wrong SLD wire in the DB9 , how can i take it out without damaging it?
Default 12-07-2012, 09:02 AM
You get a DSUB pin removal tool.
Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default 12-07-2012, 04:18 PM
Who with a MT car has tried the new future use A and what settings (FUA and lagfix) have you found to work well?
2009 135i 6MT Jet Black, FBO+
SDBoosTed SDBoosTed is offline
Car: 2009 335I
Default 12-08-2012, 02:23 AM
Question is G5_ISO_15.hex the Newest Files still or is there another update that im just missing?
