(#5751)
aoschadlin's Avatar
aoschadlin aoschadlin is offline
Car: 535i
Default 11-30-2012, 05:49 PM
Originally Posted by SDBoosTed
Is there a diffrent interface for the G5 for the computer because it keeps telling me G5 is not compatable?
I had that message come up, then after simply restarting the interface software, plugging everything back in, restarting the car it went away.
Sorry it's not more use, but it just happened that once, then I could do the ISO firmware upgrade and it's all been fine since.
Cool stuff no longer installed.
SDBoosTed SDBoosTed is offline
Car: 2009 335I
Default 11-30-2012, 05:56 PM
Yea it gives me that error no matter what. basically I just want to know that there should not be a difference in the interface right like the interface should be correct or is there a different interface for the G5 that I missed... =/ Thanks for the info at least I know that it just might be a error to my error lol
aoschadlin's Avatar
Car: 535i
Default 11-30-2012, 06:08 PM
No, it's the same interface. Although you will need the latest so that it's aware of the G5.
drm916 drm916 is offline
Car: 08 335i
Default 11-30-2012, 07:15 PM
Plus you need to select G5 in the drop down...
Car: 2009 335I
Default 11-30-2012, 09:07 PM
Alright thanks gents
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 12-01-2012, 05:10 AM
Hi guys i have questions about map 1 and map 5. My mods are jb4 g4, bms dci, air scoop, sprint booster, 2nd *** delete and muffler delete. Which map is best and power for daily drive? For when im racing i will be fillin ron 97 and on map 2. Otherwise just ron 95. Thanks!
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Default 12-01-2012, 05:30 AM
Map 5 is the place to be now, unless you have meth.
It's better than 1 and 2, but you can easily compare by changing on steering wheel.
erwan35's Avatar
Car: bmw 335i e92
Default 12-01-2012, 06:32 AM
Ok thanks! everyone agrees?
kev335i's Avatar
kev335i kev335i is offline
Car: E93 335i
Default 12-01-2012, 09:52 AM
3) Settings indicated in photo below must be entered. I would suggest ticking off the "do not reset settings when updating firmware" box in the JB4 interface to avoid causing yourself headaches down the line.
I accidently reset settings upon latest firmware upload. Anyone know the default settings so I can enter them all in?
Mods: JB4 (G5 ISO), Cobb AP V3, Aquamist HFS-4, BMS DCI, AR Design DP's, ETS FMIC, ETS Charge Pipe, HKS SSQV BOV, BMS CDV, BMS OCC & BMS Clutch Stop..... so far!
Default 12-01-2012, 10:08 AM
Select "G5 ISO" and "restore defaults" Using the 10/23 interface.
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 12-01-2012, 10:20 AM
Map 5
ditch the sprintbooster as it more for cars without a tune. The JB4 will most likely override it with it's controls.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
kev335i's Avatar
Car: E93 335i
Default 12-01-2012, 10:37 AM
Thanks Terry
rudypoochris rudypoochris is offline
Default 12-01-2012, 11:29 AM
Iso 14 is fantastic. Really loving it!
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
dreadnaxt dreadnaxt is offline
Default 12-01-2012, 01:14 PM
Originally Posted by rudypoochris
It just doesn't work that way. I am running 17.5psi and well over 400whp through stock ***.
tried today with 98 octane (your 93 i think), saw 16psi at some point
but then was concentrated on the road :D
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 12-01-2012, 04:34 PM
finally taking full advantage of ISO with big twins working correctly, cant wait for lsd and cobb/bsm flash
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 12-01-2012, 05:11 PM
just installed the flash and wow!! Only word I can say...what a huge difference!
Just installed the meth trunk mount but am confused a bit on mixing denatured alcohol with water for a 50/50 mix (getting M1) Wednesday so this will do.
Any pointers on mixing? I was thinking 55oz water 73oz denatured?
Default 12-01-2012, 06:03 PM
Rob,
I was running pure M1 until I discovered it needs some agua.
So now I just mix with regular -20F ww fluid about 50/50. Since the ww fluid has some alcohol in it you end up with a good mix.
Maybe others do it differently.
Not trying to sound cool about the "agua." I just watched No Country for Old Men again the other night and couldn't help myself. Love that movie, total classic.
"Call it!"
robc1976's Avatar
Car: 2007 335i
Default 12-01-2012, 06:10 PM
Originally Posted by Ocean
Rob,
"Call it!"
I am a newbie to meth so you use 50% -20 on 50% M1
Default 12-01-2012, 08:38 PM
what are some of the things you noticed with the flash, also, your signature has 2 sets of RBs listed...lol...your **** must be fast
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 12-01-2012, 08:49 PM
ISO 14 is head over heals better than 13-13B because -> so far no rattling from my loose wastegates on ISO 14 unlike ISO 13 which I, and apparently others, couldn't get under control no matter which setting w/ lagfix. In terms of performance, there I haven't noticed any difference between ISO 11 - 14 in terms of power, aside from smoother throttle input and reduced the slight oscillations during light throttle on ISO 11.
thanks again for allowing me to run the latest firmware.
erwan35's Avatar
Car: bmw 335i e92
Default 12-01-2012, 09:04 PM
Noted Thanks!
robc1976's Avatar
Car: 2007 335i
Default 12-01-2012, 09:30 PM
the smoothness, lag is just gone...higher RPMS much better, no fuel codes or anything and car is just crazy fast.
1. Pulls harder and more linear
2. Lag is totally gone
3. Seems like a lot more lowered end throttle and higher end throttle.
4. Insanely smooth
I have quad turbos!!!!!
Default 12-01-2012, 10:43 PM
4. Insanely smooth
Are you sure that isn't ISO 14C? The 14C is amazing ****. I think I am going meth before flash. =]
2008 335i Coupe 6MT
Default 12-01-2012, 11:09 PM
The posted firmware was what was passed around via email as 14C.
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 12-01-2012, 11:55 PM
Greetings. Today I replaced the ISO_11 firmware with the new ISO_14.
When the firmware is updated like this, should I "restore defaults"?
Or are the ISO_11 settings the same as ISO_14, so no need to restore defaults?
Thanks. Might finally be able to get some logs on Map 3 with 50 additive later today.
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
