(#5501)
drm916 drm916 is offline
Car: 08 335i
Default 10-30-2012, 06:32 AM
Originally Posted by enrita
i would just run the G5 till the ISO is out of the testing phase.
Check the ISO thread and no if you got G5 is non ISO out of the box = you need to cut the diodes, upload firmaware.
Its pretty stable and smooth so far. I went ISO about 2 weeks ago. Way smoother.
AWil335i's Avatar
AWil335i AWil335i is offline
Default 10-30-2012, 07:39 AM
Originally Posted by Rob S.
Allright, i will just run the G5 non ISO for now.
I can always update to ISO in the future.
When I received the G5 upgrade, I went ahead and cut the diodes and went with the alpha ISO firmware. Might as well do it now when you have the car apart. Not that it's a ton of work, but you'll save some time in a few weeks.
Although I'm sure Terry has a lot more testing he wants to do, I doubt you'll think of this as an "alpha" product once you get it installed.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Rob S. Rob S. is offline
Car: E92 335i M-Sport
Default 10-30-2012, 07:49 AM
Ok then i will just do it. Cutting the diodes is simple...but how do i get the ISO firmware? I'm sorry...never had a turbo engine and since i'm from Holland it's not always so easy to understand everything i read
enrita's Avatar
enrita enrita is offline
Default 10-30-2012, 08:03 AM
thats exactly why you should get acquainted with the tune first in his std version and try to learn how it works etc.
Also more interesting to actually feel the difference when you go from std. G5 to G5 ISO.
up to you, the firmware for the ISO is available on a thread here, just look for it.
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 10-30-2012, 08:25 AM
Can you please make this thread a sticky?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 10-30-2012, 09:09 AM
I think it's best to just let the JB4 do the boost targeting all together even with Cobb mapping controlling fuel and advance. Just set the boost targets you want in the JB4.
But yes we've thought of having map 4 read the DME boost target, and then use that as the JB4 boost target. The JB4 would still be directly controlling boost and throttle control (no OEM PID values used), but the target would match what your flash tuning was requesting.
If anyone has the time to test it out email me and I'll code it up for you.
I would like to try this, just to have it be a possibility.. Emailing you now.. and im sure Ben would be interested as well...
e92
rudypoochris rudypoochris is offline
Default 10-30-2012, 11:11 AM
To be honest the difference for me wasn't as pronounced as for others. The boost is just more stable and doesn't overshoot for the same spool speed. I think most people who had issues with the old setup had either problems with their car or tune settings. The iso seems a lot more fool proof in that regard.
You will be happy with either, but ISO is only going to get better.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
Default 10-30-2012, 11:18 AM
Hey Terry,
My package with JB4 G5 arrived in Holland saturday, many thanks.
My 335i is stock, except for the JB4 G5 and DCI. I am going to run a 60/40 (98oct/E85) most of the the time. Can i benefit if i cut the diodes and upload the ISO firmware? Or is the ISO firmware already preloaded?
Rob
I don't envision us releasing another G5 integrated firmware version. So all future updates for the G5 will be ISO. May as well jump on board now in my opinion.
Car: 08 335i
Default 10-30-2012, 11:21 AM
Thats why I went ISO.
The car feels much smoother now and at first felt slower. But thats just cause i dont get boost spikes. Once in the upper RPMs it feel much faster. So glad I went from G4 to G5 to G5iso. G5iso FTW.
JayD JayD is offline
Default G5 ISO 11 3rd gear pull - 10-30-2012, 12:17 PM
Looks like ISO 11 is pretty solid.
08 335i w/6sp man running G5 ISO 11, DCI, intercooler, ******* DP, Performance *** back, 93 octane gas
3rd gear pull with outside temps 45.
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 10-30-2012, 04:08 PM
spool is improved vs. ISO 10, definitely not a placebo effect either. No oscillations to report of.
bv1 bv1 is offline
Car: 335i e92
Default 10-30-2012, 04:47 PM
With the BMS flash map loaded I'm assuming we can log with the G5 or the Cobb AP?
Default 10-30-2012, 05:01 PM
Nope, with the JB4 active you can only log with the JB4 interface.
Default 10-31-2012, 12:43 AM
Thnx Terry. So i just cut the diodes and that's it? Or do i still need to upload the ISO firmware? Is yes, can you please sent me a link?
enrita's Avatar
Default 10-31-2012, 01:33 AM
look att the thread in sticky called G5 ISO
Default 10-31-2012, 02:02 AM
Yes i can see 3 attached files....i'm guessing i need to download 10H or 11 but i can't open those files
Attached Files FutureUseValues.txt (999 Bytes, 211 views)
enrita's Avatar
Default 10-31-2012, 02:05 AM
you dont need to open them....
you need the jb4 interface on the laptop to load the firmware into JB4/G5 with the usb cable.
http://www.n54tech.com/forums/showthread.php?t=10605
Default 10-31-2012, 02:10 AM
Ok haha. I'm going to install the JB4 saturday...hope i will figure it out.
Default 10-31-2012, 09:18 AM
10/23 Interface
1) Added G5 ISO to the drop down, removed G5 integrated (since we won't have any future G5 integrated firmware updates), and stream lined the other model options.
2) Added interface support for the 3.5 bar map sensor for "large turbo" cars.
lecsoman lecsoman is offline
Car: 2007 E90 335i A/T
Default 10-31-2012, 12:52 PM
Originally Posted by Jl1235
Like rudypoochris said, its overboost or the car running lean. I checked if the auto clear was ON but no it was OFF. How are you guys liking the ISO in comparison to the normal G5? any smoothness difference, more pull, more safety?
thank you for your comments
More smoothness, bit more safety maybe, but no more power.
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
NihonX NihonX is offline
Car: 1M
Default 10-31-2012, 03:57 PM
I get some serious rattle when lagfix > 10. I was parking in an underground garage and noticed it.. I thought my wastegates were going bad! Lagfix on 0 fixed it though.
335is 7DCT/JB4
Default 10-31-2012, 04:43 PM
Originally Posted by JayD
Attachment 11145
I was looking at your boost which seems low for your bolt-ons (under 15psi) if I am reading the graph correctlty. What map did your run?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
robc1976's Avatar
robc1976 robc1976 is offline
Default 10-31-2012, 04:46 PM
+1 pretty low for the mods....timing has some dips to.
335is 7DCT/JB4
Default 10-31-2012, 07:55 PM
I am running better, fuel 96 octane, but only have an FMIC. Through most of the middle of the RPM range I am at 17psi +- .2
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Car: 08 335i
Default 10-31-2012, 08:26 PM
I am on iso11. I drove it around tonight and it seemed to spool a bit faster.
I Installing a new FMIC tomorrow. I will run some logs on iso11 map 2 and map 5.
Other mods are dci, ***, and chargepipe.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Rice_injected
