(#5351)
rudypoochris rudypoochris is offline
Default 10-21-2012, 10:50 PM
Originally Posted by AWil335i
40% E85/60% 93. Someone smarter than me could maybe explain why they're so low up high. I'd theorize it's a combination of my DME version and the amount of corn in Indiana. Could I have better e85 than some?
It would be the opposite actually. Less E85 would mean lower trims. I think I figured it out... you don't have an intercooler do you? What was the IAT at the end of that log?
I could see 40% and stock intercooler doing 17.5 psi and not having large trims up top since the IAT would be so hot that the density would be down. Or maybe you have a miracle car?
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 10-21-2012, 11:51 PM
Why couldn't timing recover like THIS in 4th gear? Went back to the drawing board in ATR for some tweaks and look at the result. Sigh, wasted trip to the drag strip. Best run was as 12.15@122.27 @ 19 psi.
This log is at even higher boost and it hit timing like a champ.
E90 LCI N54 6AT
AWil335i's Avatar
AWil335i AWil335i is offline
Car: 2007 335i
Default 10-22-2012, 05:28 AM
Good theory - stock intercooler (for now). IAT was 118 at the end!
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 10-22-2012, 06:37 AM
Check here: http://www.n54tech.com/forums/showpo...21&postcount=1
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* DP - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
Default 10-22-2012, 07:10 AM
Still a sweet log! Congrats
2008 335i Coupe 6MT
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 10-22-2012, 07:36 AM
Which button on the logging page is 'Trims'? I don't see it anywhere...
2008 335i stock
BostonBeemah's Avatar
Car: AW 135i
Default 10-22-2012, 08:51 AM
Originally Posted by BostonBeemah
if i don't have a backend flash but have the iso should i change my cps settings to all 0 as well?
Anyone? Im assuming no...
RIP 2008 AW/BL 135i
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-22-2012, 09:03 AM
Third column from left..... second tab up from bottom....just above "Meth".
If you do not see it then update your "user interface" version.
maxwell600 maxwell600 is offline
Car: 07 BMW 335i
Default 10-22-2012, 09:10 AM
Can someone please post an up to date Menu Guide?
Car: 2009 335i AT
Cool 10-22-2012, 09:16 AM
Originally Posted by Alex!
Thks for your anwer!
I did in that way, I would like to know:
-Do I have any risk to set it manually? (turbos, fuel pump)
-Wich is the best set up, 70? 75? 80?
If you are not getting low fuel pressure codes.... leave the auto learn function ON..... 40 is as low as auto learning will take it and 40 is best for your current amount of mix.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 10-22-2012, 09:33 AM
So if trims are over
50 then what can that be if hitting target & timing good?
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
Default 10-22-2012, 09:55 AM
Means you need to flash the ECU to get more fuel in. A little bit over is livable, it just means you are running leaner than target at those points.
2008 335i Coupe 6MT
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 10-22-2012, 10:34 AM
OK.thought so.I get spikes hitting just over 50.could flashing be a bandaid if hitting over 50?example,what if one with same setup is under 50 trim but then another with same setup is hitting over 50.say like 55-60 trim.is flashing the right answer or could there be another way of figuring out why its hitting over 50?just curious.
SOLD
PRESENT RiDE
Default 10-22-2012, 01:11 PM
If you are just a little over 50 I wouldn't worry about it. Its not going to explode. That is the limit that the ECU can add more fuel based upon what it thinks the engine is doing. 50% more than it thinks is normal is a lot.
2008 335i Coupe 6MT
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 10-22-2012, 01:37 PM
when i hit it sometimes itll randomly throw a service engine soon light. no misfire no loping just service engine soon light and reduced power what could this be?
Default 10-22-2012, 01:49 PM
Read the code, and then if you are unable to figure it out search or post in the support section.
Car: 2009 335i AT
Cool 10-22-2012, 01:56 PM
The dme does not like to run with fuel trims maxed out for too long of a time.
A spike is Ok.... running several seconds at 50 (the limit) will be flagged as something wrong by the ECU. What is your "Fuel Open Loop Mapping" value?
Do you have it set for auto learning?
Default 10-22-2012, 04:26 PM
Oh yeah, you trimmed out probably. Pull the code... You need to tweak your open loop, lower your E85 mix, or stack the flash. To be honest though at 40% mix you get 95% of the performance of a 50% mix without the chance of SES issue.
2008 335i Coupe 6MT
inferno68 inferno68 is offline
Car: BMW 1M
Default 10-22-2012, 08:02 PM
Yes that will be good if is not already up to date !
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 10-22-2012, 08:38 PM
Been running 5G-ISO 335is Map 5. For the test am mixing 50/50 93/100 octane & seat of the pants feels very strong. I hope to get a Dyno run iwith this mix within a week or two.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
mykal's Avatar
mykal mykal is offline
Car: '09 E90
Default 10-22-2012, 10:58 PM
I am also liking G5 ISO.
Car: 07 BMW 335i
Default 10-23-2012, 05:45 AM
Yes, and should be located on post #1 along with everything else.
How can I use the jb4 to its fullest potential and take advantage of all of its features if I don't know which menu does what.
fapster fapster is offline
Default 10-23-2012, 07:21 AM
Yes, really old firmware from March gives a false G5 warning. Just ignore it and when you upload the proper G4 firmware it won't come back.
Little confused...when I installed the G5, I uploaded the G5 firmware not the latest G4...was I suppose to do both?
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 10-23-2012, 07:58 AM
No, upload just the latest G5 firmware if you have a G5.
Also download the latest interface (9/1), and make sure to select G5 in the drop down menu, under the settings tab in the interface.
2014 F10 535i N55 PWG
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 10-23-2012, 08:27 AM
My car with cold weather is hating E85! Every car is different i guess.
I added 2-3 gallons of E85, then filled the whole tank up with 93 octane. so thats a pretty low mix.
Did a log about 20 miles later, and my boost seems to be capping at 15psi, and my trims are over 50..
FBO about 60*F out. 2-3 gallons of E85 to a full tank of 93 octane.
This was with auto loop on, not manually set and at a default setting of 80. At the end of the run it was at 90
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
