(#1576)
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 03-02-2011, 09:47 AM
Yea, it def. is gonna be nice to be a option via the JB4, that would be really COOL! But for not the best solution is the ziptie IMHO.
BTW, Map5 is feeling more and more better each time i drive it, im starting to like it alot.
So far it is being very consistent with good power each time i plant my foot during rolls, which i use to feel the car wasnt 100% consistent each time on Map2 for me, even though it was too hot of a map for me. Map5 doing the work is great, lower psi doesnt always mean slower car Thing is moving.
2014 F10 535i N55 PWG
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 03-02-2011, 10:27 AM
I don't know why, but I keep putting off switching to Map 5. I've been running Map 2 with DCI and 93 oct without any issues thus far (knock on wood) and I love the power it provides. I feel if I were to switch to Map 5 I would lose some power. Am I safe in assuming Map 5 would settle somewhere between Map 1 and Map 2?
vrod's Avatar
vrod vrod is offline
m power
Default 03-02-2011, 10:56 AM
Map 2 might be too aggressive for your setup so switching over to map 5 might be a safer bet even though you might lose some hp. Considering you are running 93oct and DCI you should be somewhere between Map 1 and Map 2 power wise. Correct me if i'm wrong Thanks
clifton23's Avatar
clifton23 clifton23 is offline
Default 03-02-2011, 11:05 AM
if you switch to map5 you could possibly end up feeling more powerful. If your only on DCI and 93 running map2, then most likely you are hurting performance by running too high of a map. When I had DCI and 93 octane, map1 felt more powerful then map2 no doubt.
Default 03-02-2011, 11:10 AM
Originally Posted by Bimmer Barney
You're missing my point...I am aware of the options, but in my opinion using a zip tie, or a golf tee, or unplugging a connection, is a jerry-rigged solution. My OP to Terry was asking him to program this option into the JB4 firmware.
It's on the to look at list. Been busy with more fun stuff the past week.
randomquickness randomquickness is offline
Default 03-02-2011, 11:22 AM
is the jb4 able to turn off the tire pressure light for those of us without TPMS?
Default 03-02-2011, 11:34 AM
No, that comes from the module in the trunk not the DME.
Default 03-02-2011, 11:41 AM
can I disable it somehow?
MusclezMarinara's Avatar
MusclezMarinara MusclezMarinara is offline
Ma need more protein !
Car: 2009 335i x drive
Default 03-02-2011, 12:10 PM
so you guys are running map5 on autotune>?
Sorry havent been on in awhile just updated my firmware
2009 335 xdrive - Muff Delete, JB4 (ALPHA), DCIs, V701 GM, CF Splitters, +mas
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 03-02-2011, 12:38 PM
BMW just called and my car has had the Pump and injectors replaced from what I gather. I will be picking it up tonight and installing the JB4 to do some more logging on Map 5.
-Jeff
Mods: FBO
Default 03-02-2011, 12:44 PM
-Jeff
Jeff,
other than changing over to map5 any other necessary things i need to change to activate the PID
Bimmer Barney's Avatar
Bimmer Barney Bimmer Barney is offline
Car: 07 E90 335i
Default 03-02-2011, 12:51 PM
I'm not Jeff, but no, PID is automatically activated on the latest firmware. Just switch to Map 5.
Default 03-02-2011, 01:00 PM
Very good Barney thanks
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 03-02-2011, 01:10 PM
Going to do some logging tonight in high 40's weather. Only made one map 5 pull so far and it didn't feel that great. Hoping it was the 80 degree weather, I'm counting on it picking some up more power with more pulls.
Country Roads!
Car: 2009 135i
Default 03-02-2011, 01:17 PM
+1
Mods: FBO
Trevor008's Avatar
Trevor008 Trevor008 is offline
Car: 07 e92 335i
Default 03-02-2011, 01:26 PM
Would somebody mind clueing me in on where to get the latest firmware? I thought it was in the 1st post of this thread but can't find the link. Might be blind today. Thanks
Default 03-02-2011, 01:27 PM
Bro your gunna get FLAMED lol
FIRST PAGE BOTTOM OF THREAD ONE
your excused in advance
Trevor008's Avatar
Car: 07 e92 335i
Default 03-02-2011, 01:35 PM
Thanks........ but I would have never guessed that was the file I needed being that it's way at the bottom not even labeled as such.
Flaming is for shivpost dude
Default 03-02-2011, 01:51 PM
lol
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 03-02-2011, 02:48 PM
2F6C
I unplugged it in the trunk panel, I'm guessing you did a golf tee or something? I think having it programmed in as an option would give a more "professional" solution. To me, doing a golf tee or unplugging something is a mod for a Honda, not a Bimmer. I have mine unplugged because it sounds better, but I hate knowing I have a code for it and something unplugged. Is that OCD enough for you?
I had the Zip tie at first then I unplugged from the panel and left connected on the exhaust. It doesn't matter much now since I switched to a BT Exhaust. I know how it feels with the codes sometimes. I have one for an "Alive Telephone" and have not one clue what it is.
You lost me on the OCD part??
Nick
Autobahn.......its what's for dinner!!!
Car: 07 E90 335i
Default 03-02-2011, 03:10 PM
Obsessive Compulsive Disorder - since it bothers me that I have a plug and code issue that do not affect anything.
Dirty Dog's Avatar
Default 03-02-2011, 04:12 PM
I like the sound of fun stuff.
JB4 is great but this S$%T is addictive. Can't stop always wanting more power.
I think after my ******** install I now need to reduce first gear boost. Zero Traction and occasional backfire. I still have runflats that also have no tread left.
Default 03-02-2011, 05:53 PM
I hear you. Always aiming to please. The challenge is some of these ideas we come up with take days of coding time to sort out before we can even test if they offer a benefit. But rest assured we're always cooking things up in the lab to keep your "quick fixes" satisfied.
Car: 07 E90 335i
Default 03-02-2011, 06:34 PM
Nice job, Terry. Keep up the good work.
Country Roads!
Car: 2009 135i
Default 03-02-2011, 07:50 PM
Didn't get any good logs on Map 5 tonight. Cops are thick today.
Mods: FBO
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
