(#1351)
Red135 Red135 is offline
Car: 1M
Default 02-17-2011, 02:57 PM
Did you enter the appropriate COM in the interface?
rgpwr's Avatar
rgpwr rgpwr is offline
Car: 09.e92.335i
Default 02-17-2011, 03:00 PM
Originally Posted by GbreeE90
I am trying to upload the firmware, but every time I try to connect it says "Failure: COM1"
Your USB probably runs on another COM port...
(stolen from another site)
First thing you are going to want to do is set the 'COM PORT' to the correct setting, so the JB3 interface can connect to the USB/Jb3.
So go to the tab on the top named 'Settings'.
Here is two ways to find what 'COM PORT' you connected the JB3 USB to on your computer.
Once you connected the USB and your drivers are installed usually on windows the connection for the USB status will be in your toolbar.
Double click this small icon on the bottom right to open the status window.
The USB connection status window should open up with a list of USB connections.
Boxed in red in the picture above is what you should be looking for to match and input in the JB3 interface 'COM PORT'.
In the picture for example, the USB status window shows
"USB serial port (COM7)"
Take the number 7 and input it into the JB3 interface 'COM PORT' window.
To see if this is the correct 'COM PORT' number, click 'FILE' then 'CONNECT'
http://www.bimmerboost.com/showthrea...pdate-Firmware.
[ 09.e92.335i.a52 / procede.v5 / ets.fmic / afe.intake / eibach.pro / miro.368 / dimisa.4 / cityvision.ae ]
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 02-17-2011, 03:04 PM
Doesn't really matter. DSC off if safe, 40-120mph pulls, and then 2000-7000rpm in 3rd is always good. Just keep it safe and legal. All in one CSV is easiest for me.
just need to do the logs with DSC off?
and drive 2000 rpm to 7000rpm in 3 gear?
Only that?
If the answer is yes .... for me it is much easier to do several logs. (not as dangerous)
Terry see the email please
Time is the best teacher
GbreeE90 GbreeE90 is offline
Default 02-17-2011, 03:05 PM
Thank you, I actually just got it. I re-read "Read me first" I just had to change the COM port.
If anyone sees this, READ everything first, just because it says JB3 in there doesn't mean its not important.
mikeyt13 mikeyt13 is offline
Default 02-17-2011, 03:11 PM
I update the firmware before or after I connect with the usb?
rgpwr's Avatar
Car: 09.e92.335i
Default 02-17-2011, 03:17 PM
-Put key in ignition...press start button (without pressing brake/clutch)
-So, ignition is on, car is not running
-Select connect in the interface
-upload and let it do it's thing without touching anything
-wait for "flashing successful...jb4 rebooting"
-go driving!
Default 02-17-2011, 03:20 PM
THanks buddy
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 02-17-2011, 03:30 PM
Does map 1 or Map 2 have any autotuning in it at this time with the latest firmware?
Or only Map5 has the only autotuning in it.
I ask since the firmware just before it had PID autotuning within the maps.
2014 F10 535i N55 PWG
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 02-17-2011, 03:32 PM
102 Ron isn't race gas!!
Confused by this comment. What would be considered race gas then? I have 100 octane cam2.
prelude2perfect's Avatar
Car: '07 335i
Originally Posted by 5soko
Sweet so its basically always on unless you HOLDING the button down, its not a on/off switch like i was thinking.
Great, thanks T.
I was thinking it was an on/off switch too.
Terry, you might want to change your wording in the first post from:
"Pressing steering wheel volume or talk button in 1st or 2nd gear will disable the boost limit."
to something like:
"Pressing and holding the steering wheel volume or talk button in 1st or 2nd gear will disable the boost limit. Once you release the button it will go back it's current setting."
The way you have it now sounds like it will be completely disabled by pressing either buttons while in either gear.
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Default 02-17-2011, 03:56 PM
100 octane RM2 and higher is considered race gas.
Default 02-17-2011, 03:58 PM
Originally Posted by Rysandro
It's 97-98 AKI
Probably got blended down to around 96 with what he had in car b4 tho.
I'll have to check his logs, but sounds about right. Their 98-99 RON normally performs like our 93 RM2.
Default 02-17-2011, 04:01 PM
Originally Posted by Robmaster
sorry, but i dont understand what you mean with "old JB3 bogfix code". and where is the CAN based bogfix? where can i activat it??
It's new and being tested now. If you want to help test it set bogfix to 100 and log it.
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 02-17-2011, 06:52 PM
Sent a log of the new firmware (bog fix 100) to ya
Default 02-17-2011, 08:19 PM
Hey guys, have lots of 93 octane and modified car logs on map 5. Now we need a few more 91 tune only logs! Also some logs from the other side of the world where it is currently summer time would be helpful. Looking at you AU.
Dirty Dog's Avatar
Default 02-17-2011, 09:43 PM
I'm on it T.
infinity's Avatar
metanol pawa!!
Default 02-18-2011, 12:42 AM
and drive 2000 rpm to 7000rpm in 3º gear?
Only that?
Please... it´s correct?
Orlin's Avatar
Orlin Orlin is offline
Car: 08 135i
Default 02-18-2011, 01:19 AM
Originally Posted by Dirty Dog
I'm on it T.
is 91 the same as our regular unleaded and their 93 the same as our 98 vpower?
Kongen71's Avatar
Kongen71 Kongen71 is offline
Car: E92 335i
Default 02-18-2011, 02:07 AM
Found this...
http://en.wikipedia.org/wiki/Octane_rating
Orlin's Avatar
Car: 08 135i
Default 02-18-2011, 02:22 AM
Interesting read, if the below info is correct then the fuel I am putting in my car (V-Power 98) would be much better then the fuel used in the US of A
"regular" gasoline in Australia, New Zealand, Canada and the US - RON 91–92.
Kongen71's Avatar
Car: E92 335i
Default 02-18-2011, 04:50 AM
"regular" gasoline in Australia, New Zealand, Canada and the US - RON 9192.
I think they have 93 RM2 in most states which is the same as 98 RON (V-Power 98)
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 02-18-2011, 05:11 AM
That was a very good read. Now to find more and do some research.
Autobahn.......its what's for dinner!!!
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 02-18-2011, 07:24 AM
could any 1 post his experience with map 5 auto tunning?
i would love to see this LAG or power loss during take off go away after this boost adjustment.
chiaobaby chiaobaby is offline
Car: 335I
Default 02-18-2011, 07:32 AM
look here
http://www.n54tech.com/forums/showthread.php?t=11468
HondaGoneRogue's Avatar
HondaGoneRogue HondaGoneRogue is offline
They like my swag....
Default 02-18-2011, 08:15 AM
Please... its correct?
Yes.
2015 F36 - JB4 - VSRF CP/Tube/FMIC
