keith83 keith83 is offline
Car: 135i N55
Default First Log. MAP 5, Advice Please! - 08-01-2018, 06:39 PM
I just installed JB4 on N55 135i.
Just completed some logs on MAP 5 and would like advice /opinion if everything looks ok.
Current Mods:
K&N drop in Filter,
BMW Performance Exhaust
93 Octane
Car: 135i N55
Default 08-02-2018, 10:54 AM
Bump, Advice Anyone!, Does everything look normal? Thanks
Default 08-02-2018, 11:05 AM
Log looks okay, only thing that concerns me in the hpfp value.
Car: 135i N55
Default 08-02-2018, 11:20 AM
Okay Thanks, Any reason why this would be high?, and what is a normal level?
Car: 135i N55
Default 08-02-2018, 07:19 PM
Please correct me if I'm wrong, but from what I've read my fuel pressure low should be between 50-70psi, (6.59 on log appears correct), however my Fuel Pressure High starts off at 6 (roughly 900psi) and drops to 4 (roughly 600psi) at the end of log which does not appear to be good.
Does this indicate to a bad HPFP ?
Is there any other test to confirm this?
I have also being getting longer cranks when starting from cold!
Appreciate the advice.
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 08-02-2018, 07:42 PM
HPFP looks off to me too. Check the connection. Should see higher numbers and and moving a bit more up and down.
'14 435I RWD MHD "Shoup Custom Tune" BigBoost Stage 3 Turbo Spool FX-150 XHP Trans Tune VRSF Race Cooler VRSF CP BMS Intake Borla ATAK Exhaust Custom Down-pipe Stage 3 LPFP BMP4 EKP M Performance LSD Phoenix Racing PI Intake Manifold AIC2-P controller e85 3.5 TMAP NGK 5992 Plugs "0.020"
cbrandt32 cbrandt32 is offline
Default 08-02-2018, 08:21 PM
can any one help @payam@bms http://www.n54tech.com/forums/showth...451#post602451
Car: 135i N55
Default 08-03-2018, 07:32 AM
cbrandt32 you have your own thread, stop hijacking mine , i'm looking for advice on my particular problem.
Car: 135i N55
Default 08-03-2018, 04:17 PM
Any thoughts/suggestions why high fuel pressure doesn't get higher than 6 (900psi) when WOT, and drops to 4 by end of pull.
Thanks.
Default 08-03-2018, 07:06 PM
mybad if your lpfp falls below 500 that could cause the hpfp to loose psi but also could be bad hpfp if the lpfp didnt fall out
Car: 135i N55
Default 08-04-2018, 10:38 AM
OK, I decided to take a log on MAP 0, initially having thought it might be the HPFP i'm now inclined to think its the LPFP or maybe sensor.
When driving under normal condition LPFP is reading 3.2 (well below the recommended 50 psi).
When WOT low pressure fuel then reaches 5.5 but High pressure fuel drops from 7-6 at end of run (1050 to 900 psi)
Then again when driving under normal conditions Low Pressure fuel drops to 4.3 (again below the recommended 50-70 psi).
Is it normal that LPFP is reading below 50-70 PSI?
Should the HPFP be greater than what i'm seeing at WOT?
Any ideas?
Thanks.
Car: 135i N55
Default 08-04-2018, 02:02 PM
Took a log upon start up, long crank to begin with,
Low pressure fuel is 2.2 (well below the recommended 50-70psi),
High pressure fuel is 5 (750psi which is normal for idle)
left to idle, low pressure fuel does not increase.
Does this look like an issue with Low Pressure Fuel Pump?
Advice please,
Default 08-04-2018, 03:26 PM
Size:  71.6 KB i raised my open loop fuel to 75 which help with hpfp code 3 i was getting also i reset 1-7 and drove it for a bit but at idle my lpfp64-65psi also my wastegate adaption put that to 60 when doing 1-7 reset with key on not running
